High idel
Old Dec 15, 2005 | 07:04 AM
300zx's Avatar
High idel
This morning when started her up to warm her up engine went to 2k rpm's and stayed there even after it got warm. Then it didn't want to shift without letting off the gas peddle, then driving down the highway at cruise it would shift from O.D. back down and kept doing this. Ambient temp was about 40F, engine temp indicator was showing normal, after I parked it, turned ignition off then turning key on, A/T light blinking, turned off again and then back on it wasn't blinking.
Old Dec 15, 2005 | 08:39 AM
emo236's Avatar
confuzed member
clean your throttle cables and boddies.
Old Dec 15, 2005 | 08:40 AM
emo236's Avatar
confuzed member
also check your iaa and your tps.
Old Dec 15, 2005 | 12:10 PM
CanyonCarver's Avatar
Jack Of All Trades
.............. and your coolant temp sensor.
Old Dec 15, 2005 | 01:41 PM
napoleonzheking's Avatar
F5 Hero
Just check all the connections under the hood while your at it. I had idle problems, turned out to be one of the two plugs in the VERY back of the engine bay back under on the drivers side (same kind of plug that the coolant temp sensor is, someone told me they were idle control plugs, i just believed them)
Old Dec 15, 2005 | 05:12 PM
Jack Of All Trades
Originally Posted by napoleonzheking
.........turned out to be one of the two plugs in the VERY back of the engine bay back under on the drivers side
That's where the AAC valve is.
Old Dec 16, 2005 | 04:14 AM
jaffi's Avatar
I also had high idle problems and I was afraid it was going to cost some money to fix it. I ended up pushing the connectors on the throttle position sensor together and noticed that they had worked a little free.. No more idle problems. I say you go through the entire engine bay and push all the electical connections together. It is an old car, there may be some corrosion there. A little nudge can be just enough to make continuity.
82zxturbo
Nov 1, 2007 06:32 PM
hoov100
Feb 7, 2007 09:10 PM
86redz31
Oct 8, 2002 10:08 PM
reyazul
Sep 8, 2002 03:06 PM
nissan1990
May 7, 2002 09:33 AM
