help tuning 92 tt
Old Feb 12, 2006 | 06:05 PM
91zxtt's Avatar
Check to make sure your timing is set at 15 degrees BTDC. IF it's over 15, then that could be the cause of the pinging. Which plugs do you have in it, because you should have the NGK PFR6-11's in it. Plugs should be gapped at .035" for a stage III setting (according to Z1).
Black smoke usually indicated a rich condition, not lean.
How much boost are you running?
You are running premium fuel, right?
chevyss772
Dec 16, 2009 08:59 PM
Superduner
Sep 9, 2006 01:31 PM
forcedfedz32
Oct 3, 2005 04:05 PM
allmotor300z
Apr 13, 2005 10:15 PM
yRz
May 17, 2002 06:15 PM
