a few questions
Old Jun 7, 2006 | 02:20 PM
b300z's Avatar
caught the z fever
a few questions
i decided to pull my plugs to check for any problems today, and i found out they were PFR5B-11B(stock PFR6B-11C). why would someone want to run a warmer plug? they didnt look too bad tho. 2 of them had a little residue on them, but that was about it. but im scared to boost at all now.
also, i found a little oil residue from the turbo to intercooler pipe. i origionally had just a valve cover oil leak, but do i now have a turbo seal problem?
Old Jun 7, 2006 | 02:39 PM
bardabe's Avatar
Bad Speller
nah oil in the turbo i snormal. that's what Oil catch cans are for. unfortunately the Z32 didn't come with one from factory. I have 2 OEM Sr oil catch cans if U want em.
Old Jun 7, 2006 | 06:35 PM
CanyonCarver's Avatar
Jack Of All Trades
You prolly won't have any problems with the hotter plug unless you're boosting really high. Either way, if you don't know how old they are, it's time to replace them anyway.
The oil in the i/c pipe is a sign of a leaky turbo seal. It could be a long time before you actually see the telltale sign of smoke out the exhaust tho. If it's running / boosting fine, I wouldn't worry about a little oil residue. It's a natural progression of things going from new to worn out.
Old Jun 8, 2006 | 08:39 PM
SysqoeZ32's Avatar
I have a question on, the comment bout the oil seal goin out. Which one would be going out, is the out let or the inlet, if it is the inlet, then do you have to change out the entire oil inlet tube or just the eye bolt. Let me know wats up
Old Jun 9, 2006 | 03:53 AM
Jack Of All Trades
The seals per-se on turbos that I've taken apart, that cause oil to leak into the intake or exhaust, aren't really seals. What creates the internal oil seal is the precision fit between the turbine shaft and the bearings that it rides in. A brand new turbo will weep a little oil past the bearings. As the turbo wears, the clearance between the bearings and the shaft increases, allowing more oil to leak. Hence, the natural progression of things.
The newer ball bearing turbos might have some newer types of seals, but there aren't too many seal materials that can withstand the temperatures inside a turbocharger.
A leaking oil line to the turbo will cause an external oil leak and not be the cause of oil in the intake or exhaust tracts.
Old Jun 28, 2006 | 09:01 PM
91zxtt's Avatar
Um, no. Catch cans are designed for the elimination of the PCV system, not to catch oil from a leaking turbo. If your turbos are leaking that much, then it's time to replace them.
Old Jun 29, 2006 | 08:00 AM
b300z's Avatar
caught the z fever
Originally Posted by 91zxtt
Spooky...I began to get the zdriver itch a couple days ago. Musta been cause of Rizz's b'day. Happy b'day bro.
you better be stickin around for a while too 91. im starting my rebuid soon. ill have plenty of questions. im hoping to beat your 3 page parts list from courtesy as well
also...update us about your z
Old Jul 3, 2006 | 09:20 PM
91zxtt's Avatar
Nothing new on the Z....home computer took a crap, so I bought a laptop and the Conzult program from Z1.....haven't even had time to hook it up. I've been swamped at work and the 'honey-do' list around the house. PLus it's been hotter than f*ck up here. It hit 117 degrees last week....not exactly my kind of Z weather.
Bdan57
Feb 5, 2010 12:42 PM
81-280zxnt
Nov 23, 2009 01:24 PM
81-280zxnt
Oct 20, 2009 12:02 PM
SandW
Oct 11, 2006 08:08 AM
pearly whites
Aug 18, 2004 06:20 PM
