Clutch problem
Old Feb 6, 2005 | 08:58 PM
bardabe's Avatar
Bad Speller
well I have a pretty big problem. my clutvh started loosing pressure when the car got warm and it got to a point where the pedal only kicked back like 5 inches. not alot. so I kept the car like this for like 3 weeks or so. and now when I was on my way home I passed to kraggen to buy some engine enamel paint (for my brake calipers) and the clutch died completly. it does not let go of the gear when the pedal is fully pressed in. and it does not kick back. I can pull it back by hand, but it does not help. I turn the car off and pump the pedal by hand and it generates pressure. when I turn the car on it looses the pressure completly after I pump it onece and when the pedal is in it engages the clutch again slowly. and when I pump the clutch the fluid level of the recervoir drops. what's going on? I heard that my Slave cylinder might have gone out. is this true? or what else should I replace?
Long story short. the car lost the clutch pedal pressure completly and the pedal dosen't kick back. I can pull it back but it still does not get any pressure.
Old Feb 6, 2005 | 09:11 PM
My Fairlady Z's Avatar
Ruined By Spudz
Sounds like slave cylinder, you could try to bleed the system to troubleshoot the problem but ultimatley it seems like you may be in need of one.
Old Feb 7, 2005 | 03:03 PM
Riz Z Speed's Avatar
Administrative Brown Guy
Bardabe,
If you have an issue, don't hijack someone else's thread.
Start a new one.
Thread split.
Old Feb 7, 2005 | 03:54 PM
entropy31's Avatar
The Cake Is A Lie!
well I'll be thamned!!!! by my count there are only 3 spelling errors in this entire post. where did the real bardabe go??? good job!
Old Feb 7, 2005 | 04:08 PM
bardabe's Avatar
Bad Speller
oh sorry about the thread splitting. I just wanted to make sure I was ordering the right parts. and as far as the spellign errors well I took my time this time. so horray!
Old Feb 7, 2005 | 07:19 PM
91zxtt's Avatar
I doesn't sound like a clutch problem...it sounds like you need a slave cylinder. Consider yourself lucky....the slave cylinder is only $30 and quite easy to replace.
Old Feb 10, 2005 | 07:10 PM
bardabe's Avatar
Bad Speller
ok My parts come in tomorrow (friday teh 11th) and I just wanted to ask for any advice possible. there is so much air int eh system that the peddal literaly goes down on it's own. I got the slave cylinder and a pair of speed bleeders off from Z1. any advice or anithing to make sure I do it right. what tools and prosedures I wanna do it right the first time. unfortunately I work saturday and sunday so Im not goign to school on monday and Im gonna do it. so i'm open for advice and instructions.
Old Feb 10, 2005 | 07:58 PM
91zxtt's Avatar
link page!!
Yardjass
Apr 8, 2012 07:58 AM
snwbrderphat540
28
Apr 29, 2008 11:43 AM
anyrug
Mar 11, 2007 08:05 PM
Fourtunata
Jul 30, 2006 04:31 PM
MarkieMark
Sep 13, 2005 05:25 PM
