Brake "light" inquiry
Old Dec 10, 2004 | 01:37 AM
topdoggcarlos's Avatar
I had a question. Whenever I brake a light comes one that says "brake light", is this suppose to happen because none of my brake bulbs are burned out and the fuses are good. thanks
Old Dec 10, 2004 | 08:36 AM
91zxtt's Avatar
That's correct.
Old Dec 10, 2004 | 10:10 AM
lightspeed's Avatar
Southern Speedster
You may consider replacing the taillight bulbs if it really annoys you. You may have one >going< bad. Or you could just wait for it to possibly burn out...
I had a situation earlier with a blinker acting up (blinking fast on the right side, but normal on the left) - again with no burnt out bulbs. I replace one that seemed a bit duller than the others and the problem went away. I am convinced that the car is clairvoyant...or posessed.
Old Dec 10, 2004 | 01:18 PM
91zxtt's Avatar
Originally Posted by lightspeed
I am convinced that they car is clairvoyant...or posessed.
I'm leaning towards posessed.
Old Dec 10, 2004 | 04:59 PM
CanyonCarver's Avatar
Jack Of All Trades
I know the driver of mine is posessed....... :chug: :cheers:
Old Dec 14, 2004 | 11:28 PM
00Evan's Avatar
Banned
Check the 3 bulbs in the 3rd brake light.
My guess is one of those is burnt out.
Old Dec 22, 2004 | 01:03 PM
WhtFairLadyZ's Avatar
The other possibility that i have found is if you have the J-spec tail light upgrade. I dunno if u have done this or not, but when u install these u need to put US-spec bulbs in. If not, your brake lamp indicator will come on. It has something to do with the voltage being pulled i think, I just know when I put em my car replacing ALL the tail light bulbs was the only solution. Good Luck!
Old Dec 22, 2004 | 08:40 PM
Rogue93TT's Avatar
Any light that does not use the full 12 volts per flash or activation will pass the remaining voltage on to the flasher (hyper fast flash) or warning light (brake light). Please excuse the laymens terms. You either have a bad or partially bad bulb. The first gen led bulbs also had this problem because they did not have resistors to use up all the voltage.
Old Dec 23, 2004 | 06:55 AM
tnkrstoyco's Avatar
Loves Going Topless
Rogue the resisters are current limiters, if I remember right. Haven't stayed with my electronics in years. Also WhiteFairlady is right about the Jspec tails, I had the same problem until I changed the bulbs to us 1157's. The sensor is based on current draw and the japanese bulbs have a different draw. That's the way I understood it anyway.
TheShanMan
Mar 8, 2014 03:25 PM
hxc251
Feb 11, 2011 02:43 PM
ananimator
Dec 17, 2009 04:50 PM
PowerhungryBill
Sep 16, 2008 09:04 AM
Cronic
Dec 13, 2004 12:12 PM
