Brake Light Does Not Light Up When Braking
They light up when I turn on my headlights, but not when i brake. I checked the fuse but all i found was a fuse labeled "Brake Lamp", this ones fine. How can I fix this? Thanks
its a possibility either you have a bad brake light sensor or maybe just a bad connection/blown fuze. the brake lamp sensor is located on the brake pedal bracket. brake lights are different than running lights. turnning on your headlights shouldnt affect the brake lights. check your brake lamp sensor, and fuses, then post again.
if this was on an s30 i'd be able to tell you.... i guess i'm an expert on that
anyway, like what was previously said, check the brake switch, all plugs at the rear harness, and also check under the dash and see if all connectors are plugged in. otherwise you'll be going through the whole car with a continuity meter..
my $.02
my $.02
Dirt Winston
Mar 26, 2013 08:26 AM
joel280zt
Aug 2, 2012 06:10 AM
Turbo86
Jan 15, 2007 03:45 PM
romeopitbull
Aug 29, 2005 10:50 AM
