blue smoke out exhaust! Need Help!!!
Old Jun 1, 2015 | 09:01 PM
dave90300zxTT's Avatar
ok i need some serious help. i have done everything i can think of to fix this smoke problem and now need expert advice. just started smoking about 2mos ago and i just cant figure it out. changed pcv valves, just put in new drain back lines to turbos, new coilpacks, tps, fpr, 6ht plugs, had compression test not long ago that came out good. checked for vacuum leaks, cleaned ic pipping, so yea idk wtf to do more.... please Help?
Old Jun 1, 2015 | 10:17 PM
Skully's Avatar
How many miles? Could be the turbos seeping oil past the seals, does it constantly burn or on startup?
Old Jun 1, 2015 | 11:11 PM
blue smoke
According to the previous owner the engin was rebuilt 50k miles ago. The turbos were upgraded from t25 to t28 about 9 mos ago. I thought it was the seals on the turbos too but called the company that built them and they said it shouldnt be the turbos, key word (shouldn't ) so yea im at a loss... ive put alot of work into the car and to have this problem really sucks. Any help to pinpoint issue would be great.
Old Jun 1, 2015 | 11:13 PM
blue smoke
Does not really smoke until car is at temp... and is most noticed on deceleration and at stops. While on throttle dont notice as much.
Old Jun 1, 2015 | 11:27 PM
Skully's Avatar
Are you running cats, or test pipes? Wondering if on deceleration due to lack of pressure on one side of the impeller, its slightly pushing the seal out and leaking oil by. Have heard of it before.
Old Jun 1, 2015 | 11:31 PM
blue smoke
Megan raceing dp's, hks test pipes w/ hks high power cats and mufflers. I have not heard of the back pressure doing that.
Old Jun 1, 2015 | 11:58 PM
blue smoke
I guess tomorrow i can drop the test pipes and see if it still smokes. Thats if its being caused by the bk pressure. ..
Old Jun 2, 2015 | 12:02 AM
Skully's Avatar
I meant more the LACK of back-pressure, that is if the seal is going out, but I mean if its new, do you have stock cats, maybe slap them in and see....Could be pulling oil through valve seals on hard decel as well, but everything was rebuilt.
Old Jun 2, 2015 | 12:09 AM
blue smoke
Yea got rid of oem cats... hey would u mind calling me if thats cool? 337 540 8036
Old Jun 2, 2015 | 12:25 AM
blue smoke
Well thanks man for all the help... if u think of anything else that you may think it might also be let me know again thanks
Old Jun 10, 2015 | 01:51 PM
ZLover4Life's Avatar
Encyclopedic Knowledge
It's your turbos. I'm saying this not only because the symptoms describe bad turbo seals, but because any shop that rebuilds the stock turbos (which aren't T25, by the way, but rather TB022, which is a T25/T2 hybrid) to T28s clearly doesn't know what they're doing. And even if the shop knew what they were doing, the guy who paid for it didn't, and probably cut corners.
TwinTurbo.NET: Nissan 300ZX forum - A T28 wheel will be very inefficient in a stock compressor
P.S. Turbos don't need backpressure.
Old Jun 10, 2015 | 01:56 PM
blue smoke
You are right... yea i pulled test pipes and its my passenger side turbo. I almost have it out right now. Pain in the *** btw without pulling motor fyi! The amount of shaft play was discusting... puttin new turbo in when this one is out... thanks for responding bud!
Old Jun 10, 2015 | 02:10 PM
Skully's Avatar
Glad you figured it out. I was more trying to say that with not so good seals, lack of back-pressure will accent this problem heavily. Free-flowing exhaust is best, but when you have issues to begin with, **** escalates quick. What are you going for replacement?
Old Jun 10, 2015 | 02:16 PM
blue smoke
Jmt turbocharger t28's . Not exactly what i want but will do for now untill full 650 build... then jwt 700bb turbos!
TRBruno
Jan 13, 2012 03:22 PM
Prokopas
Mar 4, 2011 01:03 PM
SHADY280
Jan 19, 2009 07:12 PM
myfairlady
Jul 16, 2008 09:04 PM
myfairlady
Jul 16, 2008 01:48 PM
