Belt squeal
Old Mar 30, 2010 | 09:46 PM
vitaminZ's Avatar
Belt squeal
Hey guys everytime i start my car up in the morning it has this horrible squal that lasts for about 20 seconds and goes away..its the drive belt..should i spray belt dressing on it????/
thanks
Old Mar 30, 2010 | 11:51 PM
ZLover4Life's Avatar
Encyclopedic Knowledge
Figure out which one it is and tighten it. Properly tensioned belts don't need belt dressing.
Old Mar 31, 2010 | 04:56 AM
vitaminZ's Avatar
The previous owner told me he changed the power steering pump and the belt that came with it was a bit too loose..so he just never got around to changing it
Old Mar 31, 2010 | 05:19 AM
KasbeKZ's Avatar
Pr0n Addict
there's about ~4 inches of adjustment on the alternator it looks like. that belt would have to be WAY too big. check it out though. if it's at max big adjustment, and the belt is still loose, then order a new one.
Old Mar 31, 2010 | 11:31 AM
Each component on the Z32 is EASILY adjusted by simply tightening/loosening a bolt, and as KasbeKZ said, there is lots of adjustability.
Old Mar 31, 2010 | 01:38 PM
ynotmedic's Avatar
I have put several belts on mine without resolve. I continue to tighten the belts. Mine is an 88 z. Nissan designed the alternator belt to small therefore can not support the startup load. mine does the same thing untill it warms for about 30 sec. I believe its just something you will live with
hunter_t
May 11, 2014 09:40 AM
chefbigjon
350Z Brakes, Wheels, Suspension and Chassis
May 2, 2014 06:18 AM
ZCarz
Nov 22, 2009 07:07 PM
Texizgreat
Aug 8, 2007 06:08 AM
WallZ
Nov 28, 2003 06:33 PM
