All of sudden...
Old Oct 30, 2008 | 09:55 PM
domsgarage's Avatar
Tough Guy
All of sudden...
My car alarm goes off whenever it wants to.
Why?
And how do i fix this?
Thanks.
Old Oct 30, 2008 | 10:00 PM
Is it stock or aftermarket? Can you pull the fuse? Do you have a remote?
Old Oct 31, 2008 | 04:25 PM
napoleonzheking's Avatar
F5 Hero
i have this problem with mine, turns out my window break glass sensor thingie (supposed to detect distinct vibrations of glass breaking) was set super high high to the max. a strong wind was setting mine off. see if you have one of these (will be a little black box with a dial in the middle). Not all aftermarkets have one.
Old Nov 1, 2008 | 07:12 PM
domsgarage's Avatar
Tough Guy
Its the stock one.
It started happening like two weeks ago.
It has a fuse but I would rather have it working. And I think that fuse is also for the radio too, i could be wrong.
The only other thing I can think of is a battery kill switch, but I dont know how i feel about that.
Old Nov 1, 2008 | 07:20 PM
KasbeKZ's Avatar
Pr0n Addict
i don't think the battery kill switch would really help. you can cut the battery then cut it back on and the alarm is still on. you will still have to turn it back off when you hook the battery back up. but i guess if you just want to make sure that the alarm doesn't go off all day it would work. i would take the security system out. sounds like it will be pretty hard to fix.
Old Nov 1, 2008 | 10:53 PM
F5 Hero
check your under hood plunger (the little thingy that goes up and down when you open and close the hood). those commonly go out, if the rubber is off of it, and it's just the little plastic white piece, thats probably it.
Old Nov 1, 2008 | 11:43 PM
domsgarage's Avatar
Tough Guy
i went out beforeand noticed that my hood was up more on one side then it was on the other.
i left the ballast for my hids in a weird place for some reason and it was keeping the hood up a little.
hopefully this was it.
Kyle82
Oct 23, 2014 10:26 AM
TheRevKC
Feb 26, 2011 06:20 PM
davidjoe007
Mar 12, 2005 10:06 PM
Copper727
Dec 20, 2004 11:08 PM
Slick_84_AE
Aug 7, 2001 03:24 PM
