92 Loses power when I hit the brakes...
Old Feb 26, 2006 | 11:05 PM
VandiL's Avatar
Hey everyone. Thanks for taking the time to read my post.
I just bought the car about a two weeks ago. Runs like a champ but the strangest thing happens when I hit the breaks. (This problem is not always reproducible)
Tonight I was able to reproduce the problem three times in a row before it finally went away.
While driving down the road I hit the brakes and notices that it killed the headlights. I did it again and this is when the problem arose.
As the lights went out the car started “sputtering”. It acted as though it was not getting fuel but as it “sputtered” all the warning lights on the dash flickered on and off. It continued to do this for about 15 seconds and then would stop. I repeated this process several times and during one such event I put the gas pedal to the floor. The car kicked down and tried to accelerate but continued to do this. I think it’s electrical. Has anyone seen this and if so what was the culprit.
Many thanks.
Old Feb 27, 2006 | 05:16 AM
Riz Z Speed's Avatar
Administrative Brown Guy
yes it's electrical.
have the charging system checked.
Alternator or battery most likely, one or the other. i'm betting alternator.
Edit: Moved to 300ZX (Z32) Performance / Technical
Old Feb 27, 2006 | 11:30 AM
Aphrodite's Avatar
i would say check the ground cable from the battery where it connects to the frame of the car... this can get corroded and come loose, after that just start checking all power cables to see if any might be loose enough to short something when they get pushed forward in car during braking
Old Feb 27, 2006 | 11:52 AM
RodMoyes's Avatar
Doesn't post much...
^ Second... Been there, done that.
Rod.
Old Feb 27, 2006 | 12:46 PM
entropy31's Avatar
The Cake Is A Lie!
^third... had the battery cable problem on my old blazer. yours sounds more like alternator though.
Old Feb 28, 2006 | 10:26 AM
Nycz Z32's Avatar
had the same problem too...replaced the alternator and everything ran fine
audiofreak97
Nov 19, 2010 06:20 AM
Vee350GT
350Z Brakes, Wheels, Suspension and Chassis
May 18, 2010 01:57 PM
ThermalWake
Oct 22, 2009 07:49 AM
Seraphic
13
Jan 29, 2005 11:12 PM
itskris69
Jun 25, 2003 10:40 AM
