~Brakes~
Old Jan 24, 2005 | 06:36 PM
Seraphic's Avatar
Loves The Asian Chicks
~Brakes~
after hearing squeaking from my brakes, i took it by a mechanic shop and had my rear brakes replaced. i garaged my z for the winter, and after a week, i took it out for a spin, and now i dont have any brakes, whenever you tap them, there isnt any grip. i called up my mechanic and its in the shop now, again. anyone know what the problem might be ?
Old Jan 24, 2005 | 06:51 PM
CanyonCarver's Avatar
Jack Of All Trades
does the pedal go to the floor? Is there fluid in the reservoir?
Old Jan 24, 2005 | 06:56 PM
Seraphic's Avatar
yea it goes all the way to the floor
Old Jan 24, 2005 | 07:13 PM
WhtFairLadyZ's Avatar
Are their any leaks? Puddles in the garage, etc. Can u pump them up, or does it stay to the floor?
Old Jan 24, 2005 | 07:17 PM
topdoggcarlos's Avatar
you might have to bleed the brakes.
Old Jan 24, 2005 | 07:42 PM
Seraphic's Avatar
there was a slight leak of oil. nah, pumping doesnt work, still goes to the floor, any known causes ?
Old Jan 24, 2005 | 08:25 PM
bardabe's Avatar
Bad Speller
check fluid level. if the pedal is goign all the way in and no brake presure... it's a littel expensive but U are gonna have to replace the Master cylinder.
Courtesy parts... 238.75$http://www.courtesyparts.com/Merchan...de=46010-00005
then again u can call my good buddy rober over@ Z1 and get 1 for 54$ that's how much I got mine for. just replaced it recently.
Old Jan 24, 2005 | 08:46 PM
Seraphic's Avatar
thanks bardabe, i think my dad was telling me something about the master cylinder. and geez... 237 for that. i just spent 900 for my exhaust system so im outa money. ill wait and see what my mechanic says tomorrow
Old Jan 24, 2005 | 09:23 PM
bardabe's Avatar
Bad Speller
i'd go with Z1 i got mine for 54 bucks, like I said. it's hell a cheaper and U can do it yourself. it's not hard I did mine in 1hour. with a lot of chatting with my brother.
Old Jan 25, 2005 | 06:11 AM
Jack Of All Trades
I wouldn't just buy the master cylinder unless you know for sure that it's the problem. It could be the caliper piston seals or the lines. Generally, it takes two people to check this. Fill it up with fluid and pump the brakes with someone under the car. Look for leaks.
Since someone just did your rear brakes, I would suspect a problem back there. Maybe they left a bleeder loose, Or damaged a line, or screwed up and loosened the wrong bolts on the caliper.... :yikes:
Old Jan 25, 2005 | 12:36 PM
Riz Z Speed's Avatar
Administrative Brown Guy
Moved to 300ZX (Z32) Brakes, Wheels, Suspension and Chassis.
Old Jan 25, 2005 | 05:55 PM
Seraphic's Avatar
found out that the master cylinder needs replacing >.<
Old Jan 27, 2005 | 06:27 PM
bardabe's Avatar
Bad Speller
well I think my clutch master cylinder along with my slave cylinder need to be replased. when I drive the ar normal it's ok. but when it rains and I have a "Spirited" drive after about 35 mins the clutch slowly dies untill there is a point where the clutch predal only travels about 4.5 - 5.5 inches. the fluid level is fine. but I have to pump the clutch a couple a times before I can get it into gear @ a stop light. what U guy's think???
:doh:
Old Jan 29, 2005 | 11:12 PM
:doh:
Yeah I had the same problem w my car. I replaced the slave cylinder first..then i ended up buying the a clutch master cylinder. Advance carries reduild kits. But for the ease and convience, I would just buy new that way everything is how it should be.
ddatsun
22
Nov 9, 2007 08:47 AM
Smittyz33
Mar 21, 2006 11:33 AM
Fast240Z
Other Cars
Dec 1, 2005 12:35 PM
S1j9m85
May 15, 2004 10:48 AM
Al Dukes
Oct 11, 2003 01:23 PM
