1996 non turbo short block swap
Old Apr 2, 2014 | 04:16 PM
Reckthor's Avatar
Hello everyone I have a 1996 non turbo 300zx I am in need of a short block I have an offer for a twin turbo engine. But what I would like to know is if the short block from the Twin turbo engine will work with the rebuild of the non turbo engine
thank you for any help
Z
Old Apr 2, 2014 | 04:25 PM
PredatorZ's Avatar
Lower compression
many turbo engines are designed with a lower base compression, since they will be force fed air, you can design in a bit more durability with a lower compression. Naturally Aspirated (NA) cars usually run a higher compression, so if you use a turbo short block, depending on the pistons and heads you might loose some power with a drop in compression. You might need to use an engine calculator with all your specifics to gestimate your output.
eXp0N3nT1aL
Apr 6, 2013 06:56 AM
Silverbullet82
Jan 10, 2013 08:38 PM
FubarI33t
Dec 18, 2008 12:24 PM
straight hate
Mar 23, 2007 09:26 AM
SysqoeZ32
Jun 29, 2006 10:22 PM
