short block
Old Jan 10, 2013 | 11:15 AM
Silverbullet82's Avatar
short block
Hello All,
I have been reading this forum for a while. And have been slowly fixing up my project / daily driver 1982 280zx turbo. Currently it is consuming oil, 1/8" on the dipstick per 100miles. The car runs great, revs past 6000rpm, and has good power. It was smoking so I put 20-50 oil in and now it is not smoking. I have performed a compression test, 138psi to 145psi all cylinders. I also performed a leakdown test input 100psi drops to 75psi ~25% leak on all cylinders. I can only hear hissing through the rings on all cylinders. Valves all OK cuz I recently had the head redone. Here's my question. I found a short block on CL with flat top pistons for $150, (Datsun 280ZX rebuilt short block). I want to rebuild / refresh my bottom end. Wondering if $150 for the short block is a good deal, since all the machine work is completed. Also wondering if the E30 crank is OK for a turbo. Also wondering if I do go this route if I should swap the flat top pistons for dished pistions?
Thanks
Old Jan 10, 2013 | 11:49 AM
#1: How many miles are on the motor?
#2: It may be your turbocharger consuming the oil. Have you checked the j-pipe / intake for oil? Did it smoke more under boost?
#3: Unless you are going to use flat top pistons instead of the turbo dished pistons, you will still have to pull the pistons from that other motor, and re-ring your turbo pistons. You could get your turbo block checked & machined professionally for $50-$150... or do it yourself for free (or the cost of a measuring caliper and honing kit).
#4: All L-Series cranks have the same measurements. The LD28 diesel crank is for strokers.
Old Jan 10, 2013 | 12:20 PM
240060 miles. I got it last year. had the head reworked and it had a felpro head gasket so someone had been there before just no way of knowing if anything has been done to the bottom end.
J-pipe removed. intercooler installed. JWT ECU.. cobra MAF etc.
intercooling pipes are clean no oil.
I did put a new T3eo4 ebay .50 trim turbo with a full 3" exhaust. One thing I haven't done is replace the oil feed line cause I verified that it flows oil without issue. Maybe I should get a new oil feed line with a restrictor?
Any advantage of using flat top pistons over dish. I think I would prefer to stay with dished.
Yea I was originally found a shop that hot tanks the block, rebalences the crank, checks cylinder roundness, etc for $100. Just comparing the two options
Thanks
Last edited by NismoPick; Jan 10, 2013 at 01:41 PM. Reason: Divided quotes to make post legible
Old Jan 10, 2013 | 03:31 PM
Addition to #2 yes it does smokes under full boost currently 10psi.
Old Jan 10, 2013 | 08:38 PM
A good read:
https://www.zdriver.com/forums/gener...-buying-32401/
https://www.zdriver.com/forums/280zx...ts-list-36821/
Remember that as boost (lbs, psi) increases, so does compression ratio (CR). The reason the L28ET turbo motor is a 7.4:1 CR is because at full boost (6.5psi) the CR is ~10.7:1. Now do the math... the L28E flat top CR is 8.8:1, at 6.5lbs boost it would be 12.7:1. At 10psi it would be 14.8:1. That CR is insanely high for a stock L28E, SOHC motor, running 35yr old fuel management technology. The head gasket will probably be the first thing to blow.
Start with reading your spark plugs.
eXp0N3nT1aL
Apr 6, 2013 06:56 AM
FubarI33t
Dec 18, 2008 12:24 PM
SysqoeZ32
Jun 29, 2006 10:22 PM
Tony240Z
Oct 31, 2004 10:54 AM
ZChief
Mar 4, 2004 01:45 PM
