1990 n/a coil pack smoked
Old Jan 12, 2005 | 06:17 PM
craftm's Avatar
I purchaced a 1990 n/a with a bad motor. I installed a used motor, It appears to be fine. After getting it started, it ran rough .It ran for a few minutes and then the coil pack started to smoke, not sure whats going on. Is that just a bad coil pack or could something else be going on. New to the z32 world . Has anyone had this problem.
Old Jan 13, 2005 | 08:43 AM
CaptainZ's Avatar
Maybe your coil pack was just tired and needed a smoke break ?? Honestly though I would just replace it.
Old Jan 13, 2005 | 08:35 PM
91zxtt's Avatar
I have a set of 6 used if you're interested. I bought some used thinking I had a bad coil pack, or a few bad packs. That wasn't the case. I'd like to keep a couple for spares, but if you want want one, let me know.
Old Jan 14, 2005 | 04:39 PM
NISMO LMR's Avatar
Its always wise too keep a few extra coil packs laying around the garage. I would recomend buying 91zxtt's, just to have them around in case something starts going hay wire.
While your tearing in, you might as well go ahead and replace your connections, because that is a plausible reason for smoking too. The connections on Z32's tend to get quite corroded over time, because like someone said, it gets awfully hot under that bonnet.
Old Jan 14, 2005 | 05:27 PM
lightspeed's Avatar
Southern Speedster
We EE's have a joke. "Electonics run on smoke - let the smoke out and they stop working, ergo..."
Sounds like an offer from 91zxtt. I'd take him up on at least one to get you going.
Old Jan 15, 2005 | 06:30 PM
craftm's Avatar
That took care off the problem
Thanks for the offer I found a few here in Colorado Spring. That took care of the problem. Car runs great now. Thanks everyone for the help.
LogansZ
Jan 20, 2014 09:44 PM
gojoedobb
Oct 21, 2012 01:15 PM
Afrikaaner
Sep 22, 2009 08:54 AM
srimes101
May 25, 2006 03:20 PM
ihc300zxt.t.
Feb 14, 2006 02:47 PM
