Z32 Transmission issues
Old Nov 20, 2018 | 05:20 PM
kunta0908's Avatar
So I have nearly completed my LS swap. Was having an issue where I could barely shift into each gear. Turns out my shifter linkage was tightened down a bit hard on the shifter. Loosening up the bolt a half turn free'd everything up and it now shifts easily into every gear.
Decided to take the car out around the block to ensure everything was legit before towing it to the exhaust shop to build the midpipes off of my open headers.
Found out that even though it smoothly shifts into every gear, Reverse was nowhere to be found. Not that I couldn't go to 5th and pull down to engage where R should be. But when in the R location on the shift pattern, the car would still want to go forward. Every gear turned the driveshaft the same way, no location would spin it the other way, signalling reverse.
I do not have the wiring for the reverse lights hooked up yet, so I couldn't actually verify that it was absolutely, 100%, in R. But it certainly did feel like I was hitting the correct gear, as 4th was very smooth going into, and when I went 5th to R, it had a slightly more solid feel to the pull down than 4th did.
I have done what research I could, and found some solutions involving a broken reverse detent. So I lowered the transmission a bit and pulled it out. Everything looked like it was in good working order.
The only thing I do recall, is that when the transmission was purchased off of Craigslist, the owner had been in the middle of a swap, and the inspection cover on the top had been messed with, only being held on by a few screws. I did remove it completely at one point and the spring held down by it came out. I replaced the spring, but I do not recall a checkball coming out or needing to go back in.
Is there a possibility that there is no check ball under that spring and that could be the cause of my reverse issues?? Really struggling to understand why my reverse is trying to drive the car forward...
Thanks!
Old Sep 23, 2019 | 04:08 AM
allen329's Avatar
the best solution is to diagnose your complete car all the problems and minor issues will be countered then you will be able to understand better, in transmission there can be a minor issues which will be figuring out in diagnosing report, Recently I have diagnosed my Ram truck had some minor issues and i have fixed that issues now currently using that truck for Manhattan 24 Hour Towing, so far working great.
Robin O'Donnell
Aug 6, 2018 09:50 AM
bwbee2
Oct 9, 2013 12:56 PM
007max
Dec 13, 2008 11:59 AM
KENZ
Aug 18, 2005 11:13 PM
280steveX
Jun 23, 2003 06:04 PM
