will a z32tt start without the vacuum lines hooked up?
Old Jan 20, 2009 | 06:20 PM
driftracer300z's Avatar
I have the factory tech book and the pics from here. I'm looking for some real good pics of the rear passenger side vacuum.
Last edited by NismoPick; Jan 20, 2009 at 06:41 PM. Reason: feexed sum speelin' errors
Old Jan 20, 2009 | 06:40 PM
Welcome to ZDriver!
Are you asking the question that was stated in the title too? Which "vacuum lines" do you speak of? Because there are likely quite a few...
Old Jan 20, 2009 | 06:45 PM
yeah, depends on how big the lines are and how many of them, if you hold the pedal to the floor it MIGHT start.... but seriously, just get the vac lines fixed before trying to start it.
Old Jan 20, 2009 | 06:47 PM
and would smell like its dumpin fuel?
Old Jan 20, 2009 | 06:51 PM
A massive vacuum leak would definitely mess the air / fuel ratio.
Old Jan 20, 2009 | 06:55 PM
im building a 93 tt i started about 5 yrs ago by paying a shop to pull the motor and repaint the car.but instead i got the motor stollen along with my money.now im here.ordered a motor macanical boost controler and and new pipes , bovs, down pipes and hks turbo timer and some other stuff.just need a little teck help!
Old Jan 20, 2009 | 06:57 PM
And grammar / spelling help. Download Firefox... it has a built in spell check.
And we'll help best we can, but we still don't know what you are asking.
Old Jan 20, 2009 | 07:04 PM
ZLover4Life's Avatar
Encyclopedic Knowledge
He wants you to tell him how to connect all of the vacuum lines.
Old Jan 20, 2009 | 07:08 PM
That's your job. Get to!
Old Jan 20, 2009 | 09:32 PM
no just the ones on the pass side.in the rear corner.all the diagrahms run together and dont clearly show them just figured that someone may have figured out what needs to stay and what can go.ty
Old Jan 21, 2009 | 06:31 AM
napoleonzheking's Avatar
F5 Hero
http://twinturbo.info/
click on "skip intro", click on "z32", scroll down and click on vacuum lines on the left side of the page.
Old Jan 21, 2009 | 08:21 AM
that was a huge help thanks!!!!!!!!!!!!!!!!!now on the pass side there showing two selonids but i only have the one on the bracket not the second one. and where would the boost controler get hooked in at?
Old Jan 21, 2009 | 08:34 AM
The boost controller vacuum solenoid replaces the OEM wastegate solenoids.
http://www.twinturbo.net/nissan/300z...avcr/avcr.html
And did you remove the EGR valve? Because one of those solenoids is for the EGR valve... if the EGR was removed, the solenoid may be gone, leaving only one.
Old Jan 21, 2009 | 11:21 AM
i didn't pull the motor.so i dont know , it apears from what i can see it is all there except for the 2nd solenoid.now to the second part of my problem.the wiring connectors that conect to the solenoids are also missing do these come from the engine harness?
Old Jan 21, 2009 | 12:18 PM
IIRC, they actually come from kind of "underneath" the battery... between the battery and the fender. My memory could be wrong, though. Look there, though.
Old Jan 22, 2009 | 08:16 AM
i ordered another solenoid.but there is still the problem of no pigtails to hook to them.are they on the engine harrness or a seperate harness?
Old Jan 22, 2009 | 08:39 AM
F5 Hero
he just answered you but.... check to see if your EGR is still in.
there will be something like this ..
http://www.conceptzperformance.com/C...870.232.71.254
one of those will be bolted on each side towards the front of the plenum on the bottom side, is probably the easiest way to probably see if the EGR is still in. you can also see if the bolt has been inserted in the exhaust.
Old Jan 22, 2009 | 11:37 PM
it started and ran tonight!!!!!!!!!!!!!!!!! boy it sounds bad as.guys thanks for all the help.little rough but ran none the less. thanks again!!!!!
Old Jan 27, 2009 | 12:42 AM
F5 Hero
so where the EGR removed or not?
Old Jan 28, 2009 | 09:03 PM
no there still there
90NATTswap
May 12, 2009 12:22 PM
chrischicoine18
May 12, 2006 10:18 AM
Riz Z Speed
Aug 9, 2005 12:33 PM
