White smoke coming out exhaust
Old Nov 10, 2010 | 05:11 PM
Dgk910's Avatar
Well recently it has seemed that my car has excessive white smoke at idle. It has true dual exhaust all the way back and the white smoke is coming out of both sides of the exhaust. The car does not do it at first when you start it up but about 30 seconds or so after start up. Also it starts missing aswell. I did drive it up the road and back and it stopped missing but it has still smoked after it was warm before. Thought it may be head gaskets but the car has a bad heater core so I assume if I pressure test it the heater core will start leaking. Also the water in the radiator was a brownish color.
Old Nov 10, 2010 | 08:37 PM
Mrmoose's Avatar
well leave your radiator cap off and start it up, if you get bubbles coming out its your head gasket, if not its probably your valve seals and guides
Old Nov 10, 2010 | 08:38 PM
ZLover4Life's Avatar
Encyclopedic Knowledge
Brownish coolant probably just means rust... flush it out.
Compression test can diagnose bad head gasket... does sound like thatcould be your problem. White smoke is generally coolant. TT or NA?
Old Nov 10, 2010 | 09:10 PM
Dgk910's Avatar
It's twin turboed
Old Nov 10, 2010 | 09:31 PM
Mrmoose's Avatar
could also be the turbo seals going bad.... whats the oil pressure read?
Old Nov 11, 2010 | 01:07 AM
zackyv55146's Avatar
i would think that your head gasket might be going out cause the white or blueish smoke if your geting that usually means your anti-freeze is mixing with your oil somwhere
Old Nov 11, 2010 | 02:06 PM
xpwarrior's Avatar
Give the smoke a sniff test. If it's coolant and you are using antifreeze it should have a nasty sweet smell.
dajude
Aug 6, 2011 08:12 AM
ZXT83
Sep 10, 2009 01:09 PM
myfairlady
Jul 16, 2008 01:48 PM
c-murder
Oct 29, 2006 05:24 PM
rngrck
Jul 22, 2003 09:55 AM
