Weird Noise
Old Nov 4, 2008 | 08:19 PM
3riCJbOi's Avatar
one sound fits all
Weird Noise
Hey guys
Need some help again, for some weird reason i hear a weird noise when i make left turns in my car
its fine with right turns
its just when i turn left it makes a noise, what could be the problem
i check power steering fluid its fine soo what can cause this?
Old Nov 4, 2008 | 08:22 PM
SpeciallySpiked's Avatar
I'm a Registered User!
What kind of noise is it? A grinding noise? etc
I had a GMC Jimmy that I completely submerged in water - Needless to say the front bearings started going out on it. You could hear it softly all the time but turning one direction would make the grinding noise really noticeable.
So... what kind of noise is it?
Old Nov 5, 2008 | 08:07 AM
z-hag's Avatar
Queen of Yachts
please describe the weird sound, if you would---could be anything from front end to brakes ......my z31 na did noises well....similar ---was the wheel bearing and the rack and pinion......but also could be brakes or ball joints---anything---
Old Nov 5, 2008 | 08:16 AM
pft.... don't you know there can only be ONE weird noise?!
Grrrrrrr.....
Wahhh Wahhh Wahhh ....
Ping Ping Ping ....
Shhhhhhhhhhh....
Squeeeeeeeaaakkkkkk....
ppppphhhhhhhssssssss.....
Remember... one sound fits all.
Old Nov 5, 2008 | 08:22 PM
3riCJbOi's Avatar
one sound fits all
it makes a more like a grinding noise
Old Nov 5, 2008 | 08:23 PM
Wheel bearings? Worn brake pads? Something is loose?
Take of the tire and inspect.....
Old Nov 10, 2008 | 03:40 PM
chayden's Avatar
I know of a guy who experienced the same issues, a grinding noise when turning in one direction - in his case it was simply a couple of wheel nuts that loosened slightly on one of the wheels. The alloys were 18" and originally from a car with a different offset, an RX7 I believe. For some reason they loosened. Luckily he discovered the problem, but it took a while.
BMoReMoB420
Nov 9, 2007 01:18 PM
kevtt
Mar 20, 2007 07:51 PM
Fast240Z
Nov 8, 2006 03:28 PM
Zskyline79
Mar 15, 2006 09:46 PM
Zpeed Racer
Sep 22, 2003 10:37 PM
