Transmission compatibility
Old Aug 24, 2010 | 08:47 AM
atmel101's Avatar
Hi guys,
I know you are probably sick and tired of hearing about AT to MT conversions but I really need clarification as I am about to do a conversion on my 1996 Z32 N/A
What I need to know is
- will any transmission from 90-96 fit?
- can I use a TT tranny on an N/A engine
I know what else is involved and all the parts I need to acquire.
Old Aug 24, 2010 | 09:08 AM
xpwarrior's Avatar
http://upload.z1motorsports.com/Z1%2...ion%20Tech.pdf
Old Aug 24, 2010 | 10:42 AM
BlueKitsune's Avatar
Intrawebz Wizard
I did it and theres was 2 hangups on the issue, Running the clutch line with the engine in is near impossible, And My engine was a weirdo which had an undersized hole for the pilot bushing making it so I couldnt stab the trans in. I ended up using a ball hone the OD size of the transmission shaft and ran it though the center of the pilot bushing after I got it installed. so far no issues.
And apparently any trans from any Z32 will work. if you use a TT flywheel in an N/A trans you have to shim out your starter.
Old Aug 24, 2010 | 11:18 AM
xpwarrior's Avatar
I did it and theres was 2 hangups on the issue, Running the clutch line with the engine in is near impossible.
http://www.z1motorsports.com/product...oducts_id=3037
Old Aug 24, 2010 | 11:23 AM
Intrawebz Wizard
That would have been nice to know about when I did that swap! But I think the hardlines will be more reliable over time
Old Aug 25, 2010 | 06:18 AM
atmel101's Avatar
thanks everyone, very helpful !!
duowing
Aug 22, 2006 09:37 AM
91Zman
Apr 5, 2006 03:06 AM
highwaystar
Dec 15, 2004 09:05 AM
newb81280zx
Oct 19, 2004 09:27 AM
mornflt
May 10, 2003 02:52 AM
