TCU (Transmission Control Unit) Interchangeability)
Old Feb 19, 2013 | 05:01 AM
bataradena's Avatar
Need some help from a Z32 GURU concerning if any TCU are interchangeable between years (excluding 96 with ODB-II)?
For example; I have a 1993.2 NA 2+2 with P/N 31036-45P00 or is the P/N A64-000-M61. I did find some 93.09 to 1995.07 TCU P/N 31036-46P00 / P/N A64-000-M68. My question there is a difference in the P/N's but looking at the 94-FSM the wiring is the same. I'm just wondering if they are interchangeable. Maybe the MFG used a different circuit inside or upgrade the TC-Software for better shifting performance.
Thanks
Old Dec 22, 2017 | 09:36 PM
Aeleven's Avatar
Did anyone help you?
Old Dec 23, 2017 | 07:08 AM
bataradena's Avatar
No, I ended up rebuilding the transmission myself after replacing the TCU, I was hoping the transmission control was at fault.
The Trans had a leak (crack) in on of the "clutch pack" near the mfg weld, a common problem I learned later.
I hope this help.
Byron in Tucson
BADASSTT
Nov 3, 2008 11:49 AM
aratheff
Nov 8, 2007 08:53 PM
Mike86NA
Feb 3, 2005 05:55 AM
Mike86NA
Dec 29, 2004 06:18 PM
ozzyruleZ
Mar 20, 2002 12:56 PM
