stalls out of nowhere.
Old Jul 27, 2015 | 03:12 PM
Matt Hidy's Avatar
i own a 1990 300z automatic 2+2 non turbo (if it matters.)
the car just dies randomly. what's weird is that their is still power from the battery to everything. the starter runs, the lights work, all the electric is there, but the car will not start back up unless it's hooked up to another battery with jumper cables. even though the starter runs when you turn the key.
i'm not much of a mechanic so please try to make your advise easy for an idiot like me to understand. thank you.
Old Jul 27, 2015 | 05:54 PM
rogerz's Avatar
Grumpy & Helpful
Get your battery load tested. Be sure you have clean, tight corrosion free terminals on both ends of your battery cables. Be sure the ground (negative) cable goes to a bolt into the frame before going to the starter. grounding through the starter is not a reliable connection. Z's don't like low voltage. causes the electronics to act funny. it is possible to have enough amps to crank but not enough voltage to run the electronics. If you have one size fit all cheapo clamp on terminals they are a problem waiting to happen. Usually on a rainy night around Oh Dark Thirty.
Clean the connectors for the maf or afm, ecu and tps. Deoxit by CAIG is probably the best connector cleaner on the market. spray with CorrosionX after cleaning and before putting together this will help prevent any further corrosion. DON'T USE DIELECTRIC GREASE.
mrprotoplasm
Jan 22, 2016 06:31 AM
red zee
Jun 10, 2015 01:55 PM
BozZ
Nov 13, 2012 03:10 PM
zedm@n
Mar 15, 2009 07:08 PM
chinesekid
Apr 10, 2006 08:51 AM
