Squealing fan clutch
Old Jun 15, 2009 | 05:41 PM
dreamz90tt's Avatar
I developed a realliy bad squeal at high rpms. After several hours I have it narrowed down to the fan clutch, but cant find anything on squealing fan? Anyone heard of an OEM Fan doing this?
Old Jun 15, 2009 | 08:58 PM
ZLover4Life's Avatar
Encyclopedic Knowledge
Get some belt dressing or check belt tension. The fan cannot squeal, but belts can.
Old Jun 16, 2009 | 07:46 AM
300zgearhead's Avatar
I have squeeling sometimes right when i start my car up and i have just about replaced everything and it still does it so i think my fan clutch could squeel too.
Old Jun 16, 2009 | 10:13 AM
But is the belt TIGHT enough? A classic sign that the belt isn't tight enough is a squeal @ start up...
Old Jun 16, 2009 | 10:35 AM
dreamz90tt's Avatar
Belts are tight and new, have replaced everything else. I am going to pull the fan off and see if it goes away only thing I have left to do. I pulled both belts, one at a time nd it still squeals.
Old Jun 17, 2009 | 06:21 AM
nzniggles's Avatar
It's probably a cam belt tensioner or water pump then
Old Jun 17, 2009 | 08:05 AM
I tightened the belt a ton past the point it should be compared my other cars. Unless the belt on the water pump is supposed to be tighter than belts normally would be. plus sometimes when i down shift it can just chirp a little.
Old Jun 17, 2009 | 08:08 AM
if he pulled both belts how could you say it was the water pump? there wouldn't be anything there to move it.
Old Jun 17, 2009 | 08:14 AM
nzniggles's Avatar
There's three belts so may have missed one (P/Steering + Water / Alt + Aircon)
Old Jun 17, 2009 | 08:41 AM
if he says both then i'm assuming he doesn't use a/c because of horsepower gains
Old Jun 17, 2009 | 08:54 AM
nzniggles's Avatar
Assumptions are the mother of all **** up's
You assumed one thing, I assumed another. Should have asked him I guess
Old Jun 18, 2009 | 06:31 AM
I guess we should have asked him then.
Old Jun 18, 2009 | 08:25 AM
nzniggles's Avatar
Hey dreamz90tt, what belts did you pull?
Old Jun 19, 2009 | 12:45 PM
dreamz90tt's Avatar
It is the fan clutch. Took the Fan off and it no longer happens.
Old Jun 19, 2009 | 12:47 PM
dreamz90tt's Avatar
Oh and took the AC and PS belts off. Did not want to run the car without the WP going.
Old Jun 19, 2009 | 10:13 PM
nzniggles's Avatar
Cool at least its sorted. Never heard of that fault before.
Old Jun 21, 2009 | 05:34 PM
I think i'll try pulling mine then how high rpm did it squeal at?
Bravenewme
Nov 18, 2014 01:22 PM
jaromgi
Dec 18, 2011 04:35 PM
pro1biz
Jun 17, 2011 12:25 AM
DallasZ_388
Mar 10, 2005 03:44 AM
gamemannn
41
Jan 26, 2005 12:02 PM
