Spark plugs
Old Jan 26, 2005 | 01:37 PM
b300z's Avatar
caught the z fever
a wide spark plug gap can cause hard cold starting, misfires during rich or lean fuel conditions, and reduction of upper rpm range, and will reduce its lifespan. to keep a good spark within a wider rpm range you should run a narrower spark plug gap.
Old Jan 26, 2005 | 08:39 PM
91zxtt's Avatar
The NGK PFR 6b-11's come pre-gapped at .045". With the ASH ECU, they recommend you gap it to .035". Other than that, I haven't read about increasing the gap to increase fuel mileage. You could bump your timing a up a couple degrees; which would give you small gains in mileage. I wouldn't go over 17 degrees of advance. Again, with the ASH ECU, they advise 15 degress, no more, no less. You can bump the timing up on a stock Z, or virtually stock Z.
Old Jan 27, 2005 | 07:55 AM
kbebrynt's Avatar
Originally Posted by 91NAZ
I have heard nothing good from gapping platinum plugs. I just replaced my old NGKs with Bosch Platinums and the car gets a few more miles to the gallon. As pain in the butt as it is to change out the plugs, I would recommend against playing with the gap.
how did the Bosch work, because i wanted to install the +4's on my car just because good advertisement i guess... but i think my spark plugs are starting to wear out and need to be replaced.
Old Jan 28, 2005 | 12:09 AM
91zxtt's Avatar
The OEM NGK plugs have been proven to outperform and non-OEM cometition becuase they thread further into the head; which pushes the plug further inside the combustion chamber, thus creating more complete combustion. Stick with NGK.
Old Jan 28, 2005 | 02:28 AM
Riz Z Speed's Avatar
Administrative Brown Guy
https://www.zdriver.com/forum/showthread.php?t=11523
i made it a sticky and placed it in Link Page.
emo236
72
Jun 6, 2017 02:50 PM
Gingie
Mar 29, 2014 07:48 AM
Riz Z Speed
300ZX Z32 Tech Tips
Sep 28, 2005 11:36 PM
Seraphic
May 14, 2005 05:10 PM
MOE
Aug 16, 2004 11:27 PM
