Spark Plug Wont Fire
Old Apr 30, 2010 | 06:35 PM
RHDave91's Avatar
Hello Everyone, I just bout a 300zx TT from a friend which got demolished by pack rats. I'm excited to get the car running, but am a little stumped at the moment.
The car turns on no problem but runs on five cylinders and I have come to the conclusion that its because I get no spark. Now it appears that the pack rats did some work on the wires to the coil pack, but I reconnected them and still no spark. After a little more testing I found out that the middle wire is the wire that carries power, I believe it was the left one that grounded it(which both are doing exactly what they should), but the third one I have no idea and im assuming is the problem to my issue. After a little bit of research I believe that this wire connects to the power transistor unit(PTU), and looks like this fails quite often from all the other posts that i've seen.
Now my question is pretty simple, Would or could the PTU cause only once cylinder to not fire? Or should I simply be looking for a chewed through wire?
Some more information that may be helpful. I changed the spark plug with a different cylinders and the spark plug was NOT the problem. I changed the coil pack with a different cylinders and it was malfunctioning BUT the original cylinder still misfired.
Thanks for any and all help.
Old Apr 30, 2010 | 06:40 PM
ZLover4Life's Avatar
Encyclopedic Knowledge
If the PTU is the newer style, it is not likely to be the problem.
How have you determined that the problem is spark? Fuel injectors are very problematic on pre-94 TTs.
Old Apr 30, 2010 | 06:44 PM
RHDave91's Avatar
I decided it was because of the spark because of a few reasons. First one being that when I pulled the spark plug it had fuel on it, and secondly because I did the whole screwdriver test and it was clicking as normal.
Old Apr 30, 2010 | 07:45 PM
That's not a valid injector test... all it tells you is that it's firing. It could be firing too much, causing your plug to be covered in fuel and not igniting because it's too rich. Test the resistance across the injector leads, it should be 10-14 ohms.
Old Apr 30, 2010 | 09:04 PM
RHDave91's Avatar
Ill have to get a multimeter tomorrow to test it and ill post the results. Thanks for the guidance.
Old Apr 30, 2010 | 09:10 PM
KasbeKZ's Avatar
Pr0n Addict
before you do that, you could check for spark. requires no special tools and may show you your problem.
Old Apr 30, 2010 | 09:20 PM
RHDave91's Avatar
How would you test for a spark? I have been told to pull the spark plug and connect everything together and ground the spark plug and try to start the car to test it, but wouldn't that cause fuel to spew everywhere which wouldn't be a good idea with a spark plug that might ignite it? Should I just remove the fuel pump relay?
Old Apr 30, 2010 | 09:39 PM
KasbeKZ's Avatar
Pr0n Addict
no, fuel wouldn't spray everywhere. the injectors aren't spraying that much.
and you don't necessarily "ground" the plug. you hold it close to a ground, so as to view the arc.
you've got the idea though.
Old Apr 30, 2010 | 10:04 PM
It appears to me that you don't have a good grasp of the fact that the injectors spray toward the back of the valves and what enters the cylinder is just a light mist of fuel.
KasbeKZ, what do you mean you don't ground the plug? Yes you do. The arc that you're observing should be from the electrode of the spark plug, and the plug will not fire if the threads are not grounded (they are usually grounded to the cylinder head into which they are inserted).
Old Apr 30, 2010 | 10:16 PM
KasbeKZ's Avatar
Pr0n Addict
you put me in a tough position here. i must do it...
i, kasbekz, submit, that zlover4life, is wrong. hold the plug away from the plenum and turn the engine over, and the spark will arc to the plenum. this is how i always do it. it's just how i was taught to do it. i've done it with several types of cars/plugs/coil configurations.
but, thanks for pointing out the technique of actually grounding it. that would be easier if only to hold the plug still.
what you're thinking is that if it's not grounded, it has no where to go, and yes, but, if it's close to the ground, it just jumps.
Old Apr 30, 2010 | 10:24 PM
RHDave91's Avatar
Your right, I didn't have a grasp on that thought. But then again that's what forums are here for, and now I can run that test with a little piece of mind.
Old Apr 30, 2010 | 10:27 PM
I am not wrong. If the plug is not grounded, it cannot spark. You're holding it close enough for it to ground, but that doesn't mean it's the correct way of doing it. When the spark plug is in the cylinder, it is grounded and the arc is from the electrode (you know that). When you want to check it, you simulate the conditions in the cylinder (i.e. the coil connected, with the spark plug at the end, and the plug grounded to something), in a situation that allows you to observe the spark (from the electrode, because that's what's supposed to fire).
You were taught wrong. In fact, I wouldn't be surprised if your method could give a false result... if there is a problem with the electrode, your method won't show it. Your way is basically only good for testing wiring and the coil itself. (But since spark plugs themselves rarely are the cause of misfiring, that's usually what's more important to check anyway.)
Old Apr 30, 2010 | 10:36 PM
KasbeKZ's Avatar
Pr0n Addict
that may be so (that my method may give a false result). but if the spark plug is not touching anything, can we say that it is grounded? it is certainly arcing.
Old Apr 30, 2010 | 10:41 PM
Electricity can flow through many mediums... including air. Is it securely grounded? Nope... but the proximity allows the circuit to be completed.
Think about it this way... the way a spark plug works is by charging the plug so much that it jumps the gap from the center electrode (which is protruding from the center of the plug) to the ground electrode (which connects to the threads, which are grounded). If there is a short inside the spark plug, your method would still arc... but the spark plug would not fire, because the electricity would never jump the gap inside the cylinder (essentially, it'd just flow through the walls of the spark plug). What you want to verify by testing a spark plug is that there is spark at the gap of the plug, because that's where it needs to be to ignite the air/fuel mixture.
My stance is still that the injector needs to be tested first. Then we'll move on to whether or not the plug is actually firing. I'll bet that it is, and if it wasn't, it was because the injector was fouling it.
Old Apr 30, 2010 | 10:56 PM
KasbeKZ's Avatar
Pr0n Addict
reading back over your posts, i guess i don't have anything to actually say "you're wrong" to, though they do all have edits! i was under the impression that you thought that if the threads weren't touching anything, then no spark would occur. but, you never said that. i retract.
Old Apr 30, 2010 | 11:17 PM
Third philosophical imperative is to question one's own statements - so I re-read everything I say multiple times and edit to eliminate any obscurity/ambiguity that could result from my word choice.
But I certainly never said that a spark couldn't occur... I simply said that such a spark wouldn't tell you what you want to know.
Be careful with when you call someone wrong.
Old May 1, 2010 | 06:46 PM
RHDave91's Avatar
I did the continuity test and it was just at 12 to 12.1 ohms. I also did it to another injector just to see what it would read and it was a little over 14 ohms.
Ill do the spark test soon, I just need to refuel after that treturous day at work.
Old May 1, 2010 | 07:35 PM
KasbeKZ's Avatar
Pr0n Addict
well, before the edit we had a different debate!
Old May 1, 2010 | 08:30 PM
I never said that your way wouldn't spark... just that it wouldn't be the proper type of spark. As I understand, you misunderstood me (and acknowledged that).
Old May 1, 2010 | 09:32 PM
RHDave91's Avatar
Well I had no luck with the spark test on account of my battery being dead. I tried jumping the car and the coilpack started to smoke and the plastic started to bubble up. I believe this is what caused the coilpack to go out in the first place. Any ideas what would cause this? short in the wire? to much voltage? Does anyone know how many volts should be running through each wire to the coilpack?
Old May 1, 2010 | 10:01 PM
It's definitely symptomatic of a short... where was the coilpack when it started doing this? I'm not sure of the voltage at the coilpack wires... never had a problem with mine. Search twinturbo.net - I've seen it discussed on there.
Old May 2, 2010 | 07:02 AM
KasbeKZ's Avatar
Pr0n Addict
yes i understand that i misunderstood you. i was just trying to make you say what you edited out! it's no big deal. just bored. exams week, and all mine are actually easy.
Old May 2, 2010 | 11:01 AM
The 12:27am post, I consolidated two paragraphs into the third paragraph, since they were related and I had a redundant statement.
In the 12:41am post, I added the entire second paragraph.
I don't delete main points... if a main point I'm considering to post is wrong, I generally catch it before submitting it (I proofread about twice before even posting).
Old May 2, 2010 | 11:46 AM
KasbeKZ's Avatar
Pr0n Addict
man i was just ribbin'! giving you a hard time. i know you wouldn't change it to make yourself right and not point it out.
G30
Oct 14, 2014 03:54 PM
Fairladyz1990AF
Apr 24, 2014 04:15 PM
halesy22
May 6, 2011 04:03 PM
cake872
21
Nov 4, 2007 08:52 AM
mnelsonz
Sep 26, 2002 10:45 AM
