racing
Old Feb 13, 2004 | 04:34 PM
pearly whites's Avatar
turboZdriver
racing
z racing tips anyone? i got a problem with losing traction on the back wheels, usually when i hit second gear and the "twin turbos....kick....in...". what are optimal shift points?
Old Feb 13, 2004 | 06:17 PM
emo236's Avatar
confuzed member
Check out this link:
http://twinturbo.net/ttnetfaq/FAQpages/shiftpoints.html
A few other things that you can do is remove the sway bar when you race so it gives the chassis more freedom to twist. Or get slicks.
Old Feb 14, 2004 | 12:10 AM
Riz Z Speed's Avatar
Administrative Brown Guy
Experiencing wheel hop? Eliminating or bracing the rear subframe bushings might help you. Solid aluminum bushings or collars to brace the bushings are available to help reduce that wheel hop and loss of traction.
Is the loss of traction in a straight line or around a corner? Certain alignment changes can help/hinder that.
Have you tried stickier tires? Tires are what connect your car with the ground. Braking and Acceleration are all dependant on your tires. A change there might greatly improve both for you.
Old Feb 14, 2004 | 11:57 AM
emo236's Avatar
confuzed member
ok, what kind of racing are you talking about? I assumed drag because you said that you were losing traction, but I guess it could be another type. It's hard to give advice without that advice. So, what kind of racing?
Old Feb 14, 2004 | 01:27 PM
turboZdriver
yes, drag of course ...
does the z stand a chance against a z06 vette?? assuming the wheels keep traction :-x
Old Feb 14, 2004 | 05:22 PM
emo236's Avatar
confuzed member
how modded? My buddies stage 4+ beat one pretty nicely. But he's also a great driver and had slicks and his sway bar taken out and his car dyno tuned before hand.
Old Feb 14, 2004 | 07:52 PM
Z_WRECKER's Avatar
how hard is it to replace the subframe bushings??? i get some wheel hop, it's annoying as hell
Old Feb 14, 2004 | 08:10 PM
NISMO LMR's Avatar
Wait did you say you were getting wheel hop? That doesnt typically happen with coil suspension does it? Mostly with leaf spring right? Traction bars corrected most of the leaf springs faults. But would slicks fit under those wheels wells, im sure some are made, but all the cars i've seen with slicks are tubbed to sh*t. Peace foo's
Old Feb 15, 2004 | 01:08 AM
It's moderately difficult to replace the subframe bushings. Having the car up in the air long enough is part of it. Lowering half the entire subframe at a time is the other part. You'll have to press/cut the old bushings out to get the new ones with or w/o spacers in.
Wheel hop is present in the Z because of there being a subrame. The rear suspension isn't technically attached to the car. Everything is attached to the subframe, then the car, with the exception of the shocks which attach to the lower a-arm and the body. But since the shock moves independently of everything else it doesn't really help stabilize anything now does it. That's no the shocks job. But back to the point, the wheels hop because the subframe bushings also help to move the entire subframe by giving and moving in place. The wheels are then allowed to move in which ever direction they so choose which includes up. Limit this movement of the entire subframe and you'll limit the upward option for the tires. So now they can either go forward or sideways.
If you wanna limit the sideways movement, a better limited slip should correct that. Stickier tires always improve the situation.
Oh, once again the reason you don't see huge 3ft wide Mickeys under a Z32 is because it wasn't meant to be dragged in the first place. BF Goodrich does make D.O.T. approved drag radials in various sizes if that's what you're looking to do with your Z or other car.
Old Feb 15, 2004 | 05:33 AM
Z_WRECKER's Avatar
so i should just cut them??? hmmmm...i guess when i thikn about it, that little bit of wheel hop is really not that annoying you can barely feel it, i might change it down the road
Old Feb 16, 2004 | 10:47 AM
91zxtt's Avatar
The down side with solid subframe bushings is the loss of ride quality. The stock bushings allow the subframe to 'float' separate from the rest of the car. The subframe will move approximately 1" before the suspension of the car begins to work. That's why you get wheel hop. If you install solid bushings, the ride becomes much more harsh and the road noise will be much greater in the cabin. You'll hear and feel everything on the road.
There are no leaf springs in a Z32, so a traction bar isn't an option. Don't waste your time reaseraching this.
Another option is subframe spacers. Check out www.specialtyz.com. I bought them, but haven't installed them yet, so at this point I only know what I have read. The subframe spacers are designed to pre-load the subframe bushings so that the rear-end doesn't 'float' anymore. The benefit to these is they reduce wheel hop, but don't sacrifice ride quality. The rubber bushings are still there to help absorb the road noise. They are supposed to be easy to install. They run $60. IMHO, these spacers are a better option since you probably spend more time on the road than on the dragstrip.
Old Feb 16, 2004 | 12:28 PM
Z_WRECKER's Avatar
thanx 91...good info good to have you back man...we haven't seen you in a few past days
Old Feb 16, 2004 | 12:42 PM
turboZdriver
what have you guys raced against and beat? nothing around my way even can stand up to the z, so i dont really have any tales to tell....
Old Feb 16, 2004 | 07:38 PM
emo236's Avatar
confuzed member
The same's for me. I haven't lost yet. The closest race was with an Audi S4. There was traffic so we didn't get to wrap out our cars but it kept up on the short bursts on the highway. But when we had a little longer stretch, I started to pull.
Old Feb 16, 2004 | 10:34 PM
turboZdriver
this one guy ruond my way bout a tt supra round the same time i got my z and before i could find him rollin round town in it i heard that he trashed it racing someone.... ugh,,,,,
Old Feb 17, 2004 | 11:41 AM
emo236's Avatar
confuzed member
that would of beeen a fun race.
Old Feb 17, 2004 | 01:27 PM
91zxtt's Avatar
Typical Supra owner. Has lots of power, but doesn't know how to use it.
Old Feb 17, 2004 | 01:46 PM
emo236's Avatar
confuzed member
pearly....are you asking for advice on street racing or strip racing? They can be pretty different (i.e. you'll want strut bars on the street, you'll want STREET tires-not slicks-on the street).
Old Feb 18, 2004 | 09:47 PM
turboZdriver
street
Old Feb 18, 2004 | 10:48 PM
emo236's Avatar
confuzed member
in that case, I only have one suggestion. This might burn out your clutch quicker, but let the clutch out as opposed to popping it out, let it out slowly and let it catch traction as you let it out.
Old Feb 19, 2004 | 09:29 AM
turboZdriver
i thinks thats what im gonna go with. shouldnt hurt the cclutch that much since i only find a quick race once in a blue moon as the saying goes.
domsgarage
Mar 31, 2009 08:45 AM
danogeno
17
Dec 7, 2007 12:31 AM
snwbrderphat540
Oct 27, 2006 08:10 AM
EZDUZIT
Sep 25, 2005 09:48 AM
ZLishous
Jan 1, 2002 04:49 PM
