No oil pressure/ticking valves
Old Dec 17, 2016 | 11:02 PM
James Nguyen's Avatar
Ok guys I have a 94 300zx NA, I have an issue with my oil pressure it's reading at 0 psi and my passenger valve is ticking a lot I spun out on the highway as I go to turn it back on it turns over but now has no oil pressure and is ticking car has 140k miles kid I bought it from states that it has 292 cams and walboro fuel pump and is mild built "just got the car"
Old Dec 18, 2016 | 06:33 PM
JSM's Avatar
JSM
Forgive me but you did check the oil to make sure you have enough?
Old Dec 18, 2016 | 07:23 PM
Yes, that was the first thing that ive checked. I have checked the oil pressure sending unit plugs and lines made sure apl of the lines were correct but even if it was the oil pressure sending unit, that wouldnt cause the ticking as if there was no oil in the head...
Old Dec 18, 2016 | 08:03 PM
JSM's Avatar
JSM
I wonder if your oil pressure valve got stuck. The oil filter relief valve is pressed into the block where the oil filter mounts. The valve opens to prevent pressure build-up, both in the oil filter and in the block. A faulty valve can cause high oil pressure if stuck closed. It can cause low oil pressure if it is stuck open or if the ball bearing is damaged. It is always best to replace a faulty valve rather than trying to repair it.
TwinTurbo.NET: Nissan 300ZX forum
Or somehow you spin caused some sludge to get sucked up into your oil pickup screen.
Old Apr 16, 2020 | 09:00 AM
cbraptor's Avatar
hello brother I have the same problem with my 300zx I just changed the lifters but it has no oil pressure and it follows the sound of the lifters that you got to repair it
RETICON
Nov 1, 2012 03:49 PM
RichardZ32
Sep 15, 2007 06:55 PM
ArmyZ
Sep 3, 2005 12:33 PM
allmotor300z
20
Mar 11, 2005 10:32 PM
Eliott
Jun 23, 2001 11:30 PM
