miss fire/Dead cylinder
Old Dec 16, 2013 | 03:32 PM
problem child's Avatar
I'm new to the forum and need some help. I have a 1990 N/A with a miss fire and potentially a dead cylinder. I already replaced the plugs and injectors I think it could be an issue with the coil pack or worst case scenario a flat spit on then cam from the previous owner also has a slight vibration. Any advice would be appreciated.
Old Dec 16, 2013 | 06:13 PM
KSpakes87's Avatar
Usually a misfire on one single cylinder is either Spark Plug, Coil Pack or Fuel Injector.
To test the coil pack and plug simply remove the coil pack and plug and insert plug into removed coil pack with the connector still hooked up. Then have someone start the car while you ground the side of the spark plug to the intake manifold. If it doesn't fire then it is either plug or coil pack.
To check if the injector is firing simply use a long screw driver and place it on top of the injector and stick your ear to the handle. It will be clicking if it's working. Compare to a known working cylinder.
If all three of these are working then it will be time to test the PTU. Here is the FSM on testing the PTU:
http://www.300zx-twinturbo.com/s.manual/efec/179.gif
If all of these things are working then it's time to start chasing down wires.
Old Dec 17, 2013 | 12:35 AM
borini63's Avatar
Check compression first.
Old Dec 17, 2013 | 06:55 AM
KSpakes87's Avatar
You will want to check compression, but not first.
Not to trying to argue with you borini63, but the tests I said to check are going to be the most likely for a dead miss on the z32. Compression test will come after identifying it is or isn't electrical. As the z32's are very prone to electrical problems and 90% of the time the problems are electrical.
Old Dec 18, 2013 | 03:36 PM
thanks KSpakes I'll give them a try but will the link u sent help on an N/A considering its a link for a TT?
Old Dec 18, 2013 | 08:11 PM
KSpakes87's Avatar
Yes. The PTU is the same for the N/A and TT.
Old Dec 19, 2013 | 09:15 AM
OK thanks
smurffz32
Nov 27, 2012 11:53 AM
HAMER177
Jul 8, 2011 12:25 AM
hondatoz32
Oct 27, 2010 05:29 PM
DarkRed86Z
Sep 24, 2010 06:43 PM
v0va
Aug 11, 2005 06:09 PM
