i think a timing problem?
Old Apr 30, 2010 | 12:50 PM
got2speed's Avatar
I just replaced the water pump on my 93 300zx n/a....
checked the timing belt but didnt take it off... i put everything back on and together and now it wont start... sounds like theres valve timing problem but just guessing ??? any suggestions...
Old Apr 30, 2010 | 02:12 PM
KasbeKZ's Avatar
Pr0n Addict
what kind of sound is it?
first thing is first, check for spark. if you didn't touch the timing belt or the tensioner, there's no reason for your valve timing to have just "gone out".
Old Apr 30, 2010 | 03:03 PM
got2speed's Avatar
like theres no spark ..or the timing is off... just sounds like it wont turn over... i didnt take the timing belt but when i was turning the crank i think i saw it rotate and the cams didnt
Old Apr 30, 2010 | 03:11 PM
Lanoi's Avatar
your harmonic balancer is spining? or crank sprocket is spining ? but cams r not. Correct??/
Old Apr 30, 2010 | 03:58 PM
got2speed's Avatar
everytihng is spinning just wont start
Old Apr 30, 2010 | 03:59 PM
got2speed's Avatar
actually the timing cover is on it so i cant see it ...
but im sure its spinning..
Old Apr 30, 2010 | 04:47 PM
Lanoi's Avatar
U gotta be sure .. tho. when your turn engine over do u hear like a POP! from exhuast? or it just cranks/turns over ?
Old Apr 30, 2010 | 06:02 PM
KasbeKZ's Avatar
Pr0n Addict
dude, CHECK spark. saying it's like there's no spark doesn't help. there is a write up somewhere for checking it. you just take a coil pack off, take the plug out, and put the plug back in the coil pack (not installed) and plug the pack in. hold the plug close to the plenum and have someone turn it over. look for an arc. it's very obvious when you see it.
and to get our terms right, "turning over" refers to the engine turning by the power of the starter. firing means making any kind of sound from the exhaust pipe i.e. combustion, and starting/running means the engine is turning on its own power.
Old May 1, 2010 | 10:36 AM
got2speed's Avatar
sorry....its definately not getting a spark... i took out the plug wire and its not getting any spark to the to the plug...the engine is turning ...i took off the timing guard to check it .. there is no pop and everything looks fine..
Old May 1, 2010 | 10:43 AM
xpwarrior's Avatar
Check the contacts on the CAS (silver thing sticking out of the timing cover on driver side). You would have needed to disconnect it to get the timing cover off and if it's not making a good connecting you won't have any spark.
Old May 1, 2010 | 11:48 AM
got2speed's Avatar
thanks i checked the contacts to make sure they were securely fastened and still no spark... anything else?
Old May 1, 2010 | 02:13 PM
KasbeKZ's Avatar
Pr0n Addict
get a multimeter and test your coil pack.
is there just one cylinder that isn't getting spark? or all of them.
did you really check for spark like i said? (on a side note, my method described was flawed. you touch the threads of the plug to the plenum and look for the spark.)
if you didn't check for spark like i said, it could be an injector problem, and probably is if your car is an early '93.
Old May 1, 2010 | 02:26 PM
got2speed's Avatar
all of them ... yeah i checked as you explained i knew what you meant... did previosly on another car...
Old May 1, 2010 | 02:28 PM
got2speed's Avatar
i hooked it up to a tester... its getting power to the positive ... but not getting the pulse to spark the chamber... sorry dont know the terminology
Old May 1, 2010 | 03:12 PM
KasbeKZ's Avatar
Pr0n Addict
did we already tell you to test the PTU and CAS? do that. those are the very most likely causes of a total loss of spark.
Old May 1, 2010 | 03:14 PM
got2speed's Avatar
sorry I just got this car not as familiar with it as others... i know what and where it is but how do i check it other than just disconnecting and reconnecting...
Old May 1, 2010 | 03:40 PM
KasbeKZ's Avatar
Pr0n Addict
alright alright. i'll look up the link for you this time, but you've got to learn how to do this after that. brb
Old May 1, 2010 | 03:47 PM
got2speed's Avatar
thx.. i appreciate the knowledge....
Old May 1, 2010 | 03:55 PM
KasbeKZ's Avatar
Pr0n Addict
i just looked the stuff up and realized i was kinda jumping the gun. check your codes.
http://www.ttzd.com/tech/diagnostictech.html
Old May 1, 2010 | 03:58 PM
got2speed's Avatar
the only code that came up was a fuel temp. sensor circuit ....
Old May 1, 2010 | 04:01 PM
got2speed's Avatar
just checked it a little while ago ... but i didnt think that is what is keeping it from getting a spark
Old May 2, 2010 | 07:10 AM
got2speed's Avatar
so what do i do from here??
Old May 2, 2010 | 07:19 AM
KasbeKZ's Avatar
Pr0n Addict
well, it's possible that your new style PTU is bad. it happens, just not very often. sadly, i have no idea how or where to find out how to test one of those. hopefully zlover can chime in with some better advise because i'm running out of ideas.
are you really sure that you properly checked for spark on each of the 6 spark plugs? this is a much different problem if you're missing spark on one or two than it is if you're missing on all 6.
mixon123
Sep 15, 2013 01:55 PM
Mike87
13
Jun 12, 2011 10:40 PM
country
Mar 18, 2011 07:27 PM
audiofreak97
Mar 13, 2010 08:30 AM
RunninOnEmpty
Sep 6, 2003 12:02 PM
