How to install a fuel cut-off switch?
Old Nov 7, 2009 | 11:43 PM
Z32FTMFW's Avatar
Anyone know of a good write-up I can go off of?
thanks
Old Nov 8, 2009 | 12:59 PM
ZLover4Life's Avatar
Encyclopedic Knowledge
Nope... but it's seriously self-evident. All you're doing is killing power to the fuel pump (or injectors, if you chose to do so). For the fuel pump, locate the power wire (or the ground - all you need to do is eliminate the circuit), run in-line switch, done. For the injectors, wire the powers of all six to a common power, toggle the common power, done. (If your Z is a pre-94TT or pre-93NA, the latter method has the benefit of preventing your injectors from going bad because it eliminates the constant power that causes the coils to short.)
Old Nov 11, 2009 | 11:58 AM
CanyonCarver's Avatar
Jack Of All Trades
I tapped into the supply side of the fuel pump relay that is behind the kick panel under the dash where the fuses are. It was easy to mount an inconspicuous switch from that area too.
Jason280ZX
Dec 26, 2013 11:37 AM
nismo619
May 14, 2012 07:21 PM
DSR300zx
Aug 14, 2006 08:34 PM
81 Black L28E
Jun 8, 2005 08:12 PM
MTP78Z
Jan 30, 2001 11:54 AM
