Hi Everyone, I'm Dave, and new to ZDrivers
Old Mar 26, 2012 | 03:18 PM
Blurr's Avatar
HI Everyone,
Im new here. My name is Dave, and I go by Blurr. Im on several other Z forums & groups with the same name, and wanted to join Z Drivers today.
Below are some photos of my Z.
I brought my Z back from the dead from a really bad previous owner. Lots of rust, neglect and problems...
Im in my 3rd year of tweaking with it. and have made alot of changes both to the interior and exterior of her. The name of my Z is Mariah.
Semi Completed list of Restoration/Modifications
New OEM Bronze Windshield with new seal
New OEM 3rd Brake light panel
New OEM Fog Lamps
New Aftermarket Cleer Corners
New OEM Nissan Emblems on panel
New OEM CAS (Crank Angle Sensor)
New OEM TPS (Throttle Position Sensor)
New OEM IACV (Idle Air Control Valve)
New OEM Plenum Gasket
New OEM IACV Gasket
New OEM IACV IACV Hoses
New OEM Fuel Hoses
New OEM Fuel Pump
New OEM Fuel Temp Sensor
New OEM Coolant Temp Sensor
New OEM Fuel Pressure Regulator
New OEM Fuel Damper
New OEM Fuel Filter
New OEM Fuel Rail
New OEM Coil Packs
New OEM Fuel Injector orings
New OEM Fuel Pump Control Module
New OEM Fuel Clamps
New OEM MAF with Breeze Clamp fittings
New OEM Turbo Outlet Connector hoses with clamps
New OEM Clutch/Flywheel Replaced at 74k
New OEM PTU w/subharness (Power Transistor unit) Recalled by nissan in August of 2011
New Stainless Steel Bolt Kit. over 255 pieces Every bolt has been replaced with Allen head studs
New Nissan Nismo 740 Injectors with CZP 740 ECU Chip
New NGK Iridium spark plugs Heat Range 8
New OEM
New OEM Radiator
New CZP PCV Kit w/hoses
New CZP Silicon Hoses Kit (All hoses replaced with Silicone)
New Z1 Radiator hoses (Upper & Lower)
New Z1 Intercooler Pipes
Nismo Oil Cap
Nismo Radiator Cap
New Tomei Duracon shift ****
New Stillen Short Shifter
New Red Stitch Shift Boot
New Red Stitch Ebrake Boot
New Red Stitch Console Cover
New OEM Rear Shelf
New Calibrated Speedo
New bronze shifter bearings
Nissan T-Top Covers
T-Top Shades
Entire Wire harness inspection/rewrap
Concourse Chrome Fuel Rail
Glowfuses retrofit for all main fuses
Interior:
Meguires Interior detail with Lexol
Carpet is clean with no rips, tears or stains.
Seats are a bit worn, but no rips, gashes or tears.
OEM Floor Mats
Complete Interior
Modifications, Customization & Exterior:
Meguires Ultra polish/claybar weekly
Kaminari High Stock spoiler with 60 LED Third Brake Light
Broadway Mirror
EBC Slotted and Drilled/Vented Brakes Package, with Red Stuff pads with less than 300 miles on them.
Bridgestone Potenza's R30 Pole Position Run flats up front
Dunlop Derezza Run Flats in the back
17 X 9.5 Inch Saleen Rims
Custom Powdercoated Balance Tube
Custom Bronze Timing Belt covers
Custom T Fitting for external Boost Controller Valve on plenum
AIV Deleted
Plastidip Moldings, all have been repainted.
Repaired Front lowe windshield Cowls, Custom Tabs for easy removal and replacement
Custom Bronze Platinum Intake Plenum, Port Matched, Ultrasonically cleaned and polished before paint
Polished Throttle Body butterflies
Custom Bronze Cable Cover with Dewla mirror finish strip
Cusco front strut bar, matte polished
CAZ Racing black hardpipe kit
Full Combination Tbolt Clamps and Breeze Clamps
Plenum Pull, Lines under plenum have been deleted
PTU Relocation under nose panel, Rewrapped with Super8 Electrical
JWT Single Pop Intake
Boost Solenoids Removed. have spare boost jets, in place is a AEM Tru Boost Electonic Boost Controller
Custom molded Steering wheel gauge pod for AEM Tru Boost
TopSpeed N1 Dual Catback Exhaust with H pipe
Stock Downpipes, and catalytic converters to pass smog bolted on
Aftermarket:
NEW Double Din GPS/Naviation Deck from Xtrons 717G
Exclusive ZThirty-Two Double Din Bezel
New KYB Excel G Suspension
Entire A/C System with compressor, fan
New Slimline HID Ballasts with 6000k Bulbs
Full LED Interior and Exterior
(2) HKS BOV SSQV4' with flanges ready for install
(2) Greddy Type RS BOV's without flanges needed for install
(1) Apex-i SAFC II
So much to do on my laundry list tho.. I haven even begun = )
I hope to meet more of you Z32 Owners here on Z Drivers in the coming days.
P.S. Moderators, I have also have a group buy for Z32's I would like to post up, any restrictions on posting?
Old Mar 26, 2012 | 06:09 PM
Welcome to ZDriver!
Gorgeous car! Did you have a photoshoot done (last pic has a watermark?)?
Old Mar 26, 2012 | 08:03 PM
Blurr's Avatar
Hi Nismo,
Thank you. No, actually thats for a new business that is starting up fabbing specialized Z32 Parts called ZThirty-Two. This is one of the products they are going to offer.
Was wondering if anyone from ZDrivers might want one. I have it up in the classifieds.
Old Mar 26, 2012 | 09:32 PM
Rupe's Avatar
Horsepower Mathematician
Super clean man. Have any more of the exterior? Maybe something that'll really bring out the true colour of it?
Old Mar 26, 2012 | 09:44 PM
Blurr's Avatar
I do Rupe. Ill post some more photos tomorrow morning = )
Thanks for the warm greeting guys!
Old Jun 1, 2012 | 11:38 AM
Blurr's Avatar
Updated my original post with some more new photos... = )
Old Jun 2, 2012 | 08:33 AM
MrShakespeere's Avatar
Dude that thing is pretty slick.
NISMO LMR
34
Apr 20, 2014 09:09 PM
duowing
Mar 2, 2009 07:41 PM
SysqoeZ32
Jan 20, 2007 11:17 PM
ThermalWake
Jan 18, 2007 12:32 PM
CanyonCarver
Aug 1, 2004 07:25 PM
