Hi Everyone, I'm Dave, and new to ZDrivers
6 Attachment(s)
HI Everyone,
Im new here. My name is Dave, and I go by Blurr. Im on several other Z forums & groups with the same name, and wanted to join Z Drivers today. Below are some photos of my Z. I brought my Z back from the dead from a really bad previous owner. Lots of rust, neglect and problems... Im in my 3rd year of tweaking with it. and have made alot of changes both to the interior and exterior of her. The name of my Z is Mariah. Semi Completed list of Restoration/Modifications New OEM Bronze Windshield with new seal New OEM 3rd Brake light panel New OEM Fog Lamps New Aftermarket Cleer Corners New OEM Nissan Emblems on panel New OEM CAS (Crank Angle Sensor) New OEM TPS (Throttle Position Sensor) New OEM IACV (Idle Air Control Valve) New OEM Plenum Gasket New OEM IACV Gasket New OEM IACV IACV Hoses New OEM Fuel Hoses New OEM Fuel Pump New OEM Fuel Temp Sensor New OEM Coolant Temp Sensor New OEM Fuel Pressure Regulator New OEM Fuel Damper New OEM Fuel Filter New OEM Fuel Rail New OEM Coil Packs New OEM Fuel Injector orings New OEM Fuel Pump Control Module New OEM Fuel Clamps New OEM MAF with Breeze Clamp fittings New OEM Turbo Outlet Connector hoses with clamps New OEM Clutch/Flywheel Replaced at 74k New OEM PTU w/subharness (Power Transistor unit) Recalled by nissan in August of 2011 New Stainless Steel Bolt Kit. over 255 pieces Every bolt has been replaced with Allen head studs New Nissan Nismo 740 Injectors with CZP 740 ECU Chip New NGK Iridium spark plugs Heat Range 8 New OEM New OEM Radiator New CZP PCV Kit w/hoses New CZP Silicon Hoses Kit (All hoses replaced with Silicone) New Z1 Radiator hoses (Upper & Lower) New Z1 Intercooler Pipes Nismo Oil Cap Nismo Radiator Cap New Tomei Duracon shift knob New Stillen Short Shifter New Red Stitch Shift Boot New Red Stitch Ebrake Boot New Red Stitch Console Cover New OEM Rear Shelf New Calibrated Speedo New bronze shifter bearings Nissan T-Top Covers T-Top Shades Entire Wire harness inspection/rewrap Concourse Chrome Fuel Rail Glowfuses retrofit for all main fuses Interior: Meguires Interior detail with Lexol Carpet is clean with no rips, tears or stains. Seats are a bit worn, but no rips, gashes or tears. OEM Floor Mats Complete Interior Modifications, Customization & Exterior: Meguires Ultra polish/claybar weekly Kaminari High Stock spoiler with 60 LED Third Brake Light Broadway Mirror EBC Slotted and Drilled/Vented Brakes Package, with Red Stuff pads with less than 300 miles on them. Bridgestone Potenza's R30 Pole Position Run flats up front Dunlop Derezza Run Flats in the back 17 X 9.5 Inch Saleen Rims Custom Powdercoated Balance Tube Custom Bronze Timing Belt covers Custom T Fitting for external Boost Controller Valve on plenum AIV Deleted Plastidip Moldings, all have been repainted. Repaired Front lowe windshield Cowls, Custom Tabs for easy removal and replacement Custom Bronze Platinum Intake Plenum, Port Matched, Ultrasonically cleaned and polished before paint Polished Throttle Body butterflies Custom Bronze Cable Cover with Dewla mirror finish strip Cusco front strut bar, matte polished CAZ Racing black hardpipe kit Full Combination Tbolt Clamps and Breeze Clamps Plenum Pull, Lines under plenum have been deleted PTU Relocation under nose panel, Rewrapped with Super8 Electrical JWT Single Pop Intake Boost Solenoids Removed. have spare boost jets, in place is a AEM Tru Boost Electonic Boost Controller Custom molded Steering wheel gauge pod for AEM Tru Boost TopSpeed N1 Dual Catback Exhaust with H pipe Stock Downpipes, and catalytic converters to pass smog bolted on Aftermarket: NEW Double Din GPS/Naviation Deck from Xtrons 717G Exclusive ZThirty-Two Double Din Bezel New KYB Excel G Suspension Entire A/C System with compressor, fan New Slimline HID Ballasts with 6000k Bulbs Full LED Interior and Exterior (2) HKS BOV SSQV4' with flanges ready for install (2) Greddy Type RS BOV's without flanges needed for install (1) Apex-i SAFC II So much to do on my laundry list tho.. I haven even begun = ) I hope to meet more of you Z32 Owners here on Z Drivers in the coming days. :023: Attachment 17856 Attachment 17857 Attachment 17858 Attachment 17859 Attachment 17860 P.S. Moderators, I have also have a group buy for Z32's I would like to post up, any restrictions on posting? Attachment 17861 |
Welcome to ZDriver! :006:
Gorgeous car! Did you have a photoshoot done (last pic has a watermark?)? |
Hi Nismo,
Thank you. No, actually thats for a new business that is starting up fabbing specialized Z32 Parts called ZThirty-Two. This is one of the products they are going to offer. Was wondering if anyone from ZDrivers might want one. I have it up in the classifieds. |
Super clean man. Have any more of the exterior? Maybe something that'll really bring out the true colour of it?
I do Rupe. Ill post some more photos tomorrow morning = )
Thanks for the warm greeting guys! |
Updated my original post with some more new photos... = )
Dude that thing is pretty slick.
