helicoil flywheel help
Old May 14, 2021 | 03:25 PM
Az32's Avatar
Hello,
I'm dumb, and I stripped crankshaft thread. Now I can't get the flywheel on... well, I could but not safe. I have 2 options. use a used crank or use Helicoil to repair the threads on the crank. I need help with the correct Helicoil to buy to insert into the end of crankshaft threads. Does anyone have a part number for me?
I will be buying new flywheel arp bolts [part#: 254-2801] to go along with the newly tapped threads. and only 2 threads are damaged, should I be worried about balancing issues now?
1990 300zx TT.
Old May 16, 2021 | 04:52 PM
Az32's Avatar
found them.
Helicoil #5542-10.. I installed them already. that was hard.. that steel is hard.
Old May 16, 2021 | 04:55 PM
Az32's Avatar
do not use the arp bots, use OEM after new threads because the OEM have a tapper on the tip that allow some wiggle room to catch the new threads.
mjselling
Oct 16, 2017 02:16 PM
Blue83
Sep 26, 2008 05:46 PM
sion
May 4, 2006 04:26 PM
SAMBOZ
Oct 9, 2004 10:12 PM
Drax240z
Apr 1, 2001 06:48 PM
