Flywheel removal tips
Old Sep 26, 2008 | 03:02 PM
Blue83's Avatar
Any tips for removing a flywheel in my 83 280ZX? Or is it just a brute force type deal?
Old Sep 26, 2008 | 03:22 PM
have an air powered impact wrench to break them flywheel bolts loose, then it should come off with little rocking motion. just try and get some good ARP flywheel bolts when you re-install it though.
Old Sep 26, 2008 | 03:52 PM
x2 on the impact. Or have a ratchet on the crank pulley along with a pipe attached to it, against the ground.
Old Sep 26, 2008 | 04:13 PM
i broke three ratchets and four breaker bars trying that, then just got fed up with driving to sears and bought myself a nice snap on air powered impact. either way its gonna suck getting the flywheel off, especially if its still in the car.
edit 1-be prepared for the motor to turn over or your harmonic balancer bolt coming loose if you do it without an impact.
Old Sep 26, 2008 | 05:33 PM
duowing's Avatar
NisTuner
Would the car still be likely to turn over if you've got the battery disconnected? I mean there wouldn't be any current to power the ignition or fire the injectors.
Old Sep 26, 2008 | 05:38 PM
i meant, as you have so much force being applied to it, that you physically turn the motor over by hand
Old Sep 26, 2008 | 05:46 PM
rtmorgan's Avatar
Obsessive Craigslist Disorder
try a breaker bar instead of a rachet against the ground
ThermalWake
Jun 18, 2009 11:42 AM
DATSUNSOCAL
Jan 11, 2007 05:07 PM
gochnour44
Oct 2, 2006 08:22 PM
gabrielzzz
Aug 8, 2005 08:31 PM
AllmyZs
Mar 13, 2004 04:32 PM
