fuel pump problem
fuel pump problem
I have a 1991 300zx tt , just got done upgrading the fuel injectors .. when I went to start it the fuel pump came on and shut off... it did this a few times ...I was wondering if anyone had any ideas
I already upgrded the ecu from jim wolf technology ...... list of some upgrades 550 turbos , jim wolf twin pop charger , rods and pistons , blitz boost controller , apexi super air flow converter , blitz turbo timer , nismo injectors
the pump doesn't turn right on when the key turns.....it will come on for alittle bit the shut off ( like it looses power ) I have a fuel regulator on the fuel line... it climbs to about 45 psi and drops
Start with a new relay and clean all of the electrical connections in the fuel pump circuit. If that doesn't fix it, maybe try running some wires straight from the battery to the pump to see if the pump still turns off in the same manner. If the pump runs fine that way, there's a chance the fuel pump controller is bad. I dunno how to check it without swapping in a known good one.
ern
Oct 20, 2006 07:01 AM
Creator
Oct 17, 2002 10:16 AM
