AH HA! Think i found the problem; Elec Fuel Pump
Old Oct 12, 2002 | 06:13 AM
Creator's Avatar
Alright, I think i found the problem with my 260z in 5th gear over 3500RPM (Popping through the carb/backfiring through the carb).
Alright, so after a shitload of troubleshooting, trying to figure out why it was backfiring through the carb, i think i have it nailed down, i tried a different electronic fuel pump the other day, and now i can get it upto about 4000-4200 before she continues to backfire, does anyone know of a good fuel pump thats good for about 6-8PSI (for carbs) or any High volume, but not High Pressure fuel pump? I'd prefer to stay with an electric one (as manual pumps suck).
Any ideas?
thanks
.cre
Old Oct 12, 2002 | 07:31 AM
Creator's Avatar
Re: AH HA! Think i found the problem; Elec Fuel Pump
yeah, i already pulled my carbs apart, checked the needles, checked the bowls, etc. and they were all ok, i was running it fairly rich to get it to perform right, but im tired of pushing gas at low RPM, plus to get the popping to go away, it would be VERY rich at low rpm.
Old Oct 13, 2002 | 06:30 AM
Creator's Avatar
hrmm.. I'm not 100% sure, I'll have to check when i go home tonight. Thanks for the tip
.cre
Old Oct 16, 2002 | 09:11 PM
Creator's Avatar
yeh i checked it out, on the carb near Cyl #1, there is a plug on the top next to the gas line (gas line is furthest to the front of the engine), and the plug is in the slot next to it (closer to the rear of the engine). The only reason i think its the Fuel Pump, is that with the time i've noticed that it got better was with a higher flow pump (well, a newer pump). so im hoping that increasing the flow a bit more, may get rid of the popping out of my carbs at high rpm in 5th gear.
.cre
hunterwolfgara
Sep 2, 2013 06:01 PM
preludetwofast
Aug 5, 2010 01:08 PM
nismo619
Sep 21, 2006 06:06 PM
ihc300zxt.t.
Apr 12, 2006 06:21 PM
FubarI33t
Oct 25, 2005 12:04 PM
