Finally some progress...
Old May 15, 2008 | 04:05 PM
chitown300zx's Avatar
Well it took longer than I wanted but after a bunch of shipments for hoses, bolts, washers etc... its finally coming back together...
Attached Thumbnails Finally some progress...-image_624.jpg   Finally some progress...-image_625.jpg   Finally some progress...-image_847.jpg   Finally some progress...-image_857.jpg   Finally some progress...-image_874.jpg
Old May 15, 2008 | 05:52 PM
ZLover4Life's Avatar
Encyclopedic Knowledge
Sorry I didn't make it out to help you... things keep coming up that end up occupying all my time. Glad to see it's coming back together though.
Old May 15, 2008 | 06:27 PM
Dude, no problem, got through a lot of the boring stuff. Still could use your help with the vacuum lines if you have a night coming up I would take you up on an offer... hope you family hookup went well. Doesn't look to bad considering this is the very 1st car mechanic type thing I have ever tried...
Old May 15, 2008 | 06:32 PM
Goofyz's Avatar
Looking good
is that a full engine rebuild?
Old May 16, 2008 | 07:23 AM
nope, just down to the fuel rail, the initial thing was injector replacement but the more I pulled off the more I realized that a TON of stuff needed to be done... she's 18 and was showing age on every hose, gasket etc...
Old May 18, 2008 | 05:30 PM
Goofyz's Avatar
I'm also doing a rebuild
Where are you getting your hoses/PCV, vaccum, Silicone and such from? So far it seems Courtesy Nissan is cheapest for the preform stuff and Conceptz has the PCV cheaper... You found something cheaper?
Old May 18, 2008 | 05:35 PM
Originally Posted by Goofyz
Where are you getting your hoses/PVC, vaccum, Silicone and such from? So far it seems Courtesy Nissan is cheapest for the preform stuff and Conceptz has the PVC cheaper... You found something cheaper?
PVC? thats a type of plumbing tube, PCV is a type of valve for crankcase ventilation.
Old May 18, 2008 | 10:29 PM
Goofyz's Avatar
Meaning of it you got, thank you correction I do, fix it I did, dyslexia perhaps the cuase?
I wonder if there is a list that someone can look up, that has all those little hoses that break when you take out an engine that has been in a car for 12 years... PCV, brake booster hoses, those stupid hard hoses behind the engine... There has to be better then OEM oil cooler lines Anyone have any ideas?
Also, whats the deal with those plastic wire harness shields on both sides of the upper plenum. What drunk Japanese 1st year engineer designed that?
BoulderZ
Apr 20, 2007 09:48 AM
DarrellBuddy321
Mar 31, 2006 03:53 PM
RPS13_GZ32
Apr 18, 2005 07:59 PM
Skully
Dec 7, 2004 03:11 PM
b300z
20
Nov 6, 2004 05:32 AM
