Electrical Problems (alternator died twice)
Old Mar 23, 2016 | 12:06 AM
immune2insanity's Avatar
1990 auto na.
I've had two alternators go bad, each time the car tried to die while driving at night (headlights, heat, and radio all on) the only way I could keep it from dying was turning off the headlights and one other system. ABS light comes on and lights dim, rpms drop, heater fan slows & radio turns off. If I am stopped, rpms fall so far the car stalls. I have checked fuses, and completely unplugged stereo amp and radio right after replacing the alternator the first time, so a hacked wiring job there is not the issue. I have noticed that there is aftermarket wiring to the injectors. How would I go about testing it? That is the only wiring I can find (other than sound system) that is not stock. Where is common for faulty wiring causing a drain? Any advise is appreciated!
Old Mar 24, 2016 | 07:00 AM
Welcome to ZDriver!
#1: Where are you getting these alternators from? Parts store alternators have a high failure rate... Autozone / O'Reilly's love to rebuild as cheaply as possible.
#2: Have you done a battery / alternator load test?
Hakkapell
Jun 11, 2013 08:04 PM
Velox ZX
Jun 3, 2011 12:49 PM
Trevor280z
Jul 10, 2003 08:24 AM
sonic
Jul 1, 2002 07:19 PM
sonic
Feb 11, 2002 06:36 AM
