Electrical Problem HELP!
Old Apr 12, 2014 | 06:38 PM
Broaddus's Avatar
No Power Windows, No A/C, No Turn Signals but hazards still work, Anti-lock Light is on. I have had this set of electrical problems for a little over a month now. I swapped the alternator and all the Fuses are still good. I NEED HELP 1990 N/A any ideas/ suggestions?
Old Apr 12, 2014 | 07:13 PM
PredatorZ's Avatar
Fsm
Do you have a copy of your FSM, you can get them free online.
Have you checked your Fusible Links ? Sounds like one of them has blown, it is a slow burn style fuse, most of your major systems are protected by them to prevent major damage to your harness.
Old Apr 12, 2014 | 07:37 PM
PredatorZ's Avatar
Fusible Location
Here is a diagram from fsm, I colored the fusible link box red.
Old Apr 12, 2014 | 07:57 PM
Broaddus's Avatar
The fusible links all look good to me, and I've swapped them to see if the problems would go away/be affected and no good, I had a guy with a multimiter check it out and he said there was no power at all going to the power windows slot of the fusible link box.
Old Apr 13, 2014 | 09:55 AM
dobber's Avatar
ok, then put a temporary 12v line to that from the battery and see if you get power? if so, check the line going to it.
zfanman
Oct 20, 2008 04:28 AM
BackHouseZ
Apr 7, 2008 11:36 PM
dragon
Feb 11, 2008 12:41 PM
NwZXlover
Jun 9, 2003 08:29 PM
