Electrical Problem HELP!
No Power Windows, No A/C, No Turn Signals but hazards still work, Anti-lock Light is on. I have had this set of electrical problems for a little over a month now. I swapped the alternator and all the Fuses are still good. I NEED HELP 1990 N/A any ideas/ suggestions?
Fsm
Do you have a copy of your FSM, you can get them free online.
Have you checked your Fusible Links ? Sounds like one of them has blown, it is a slow burn style fuse, most of your major systems are protected by them to prevent major damage to your harness. |
Fusible Location
1 Attachment(s)
Here is a diagram from fsm, I colored the fusible link box red.
Originally Posted by PredatorZ
(Post 333201)
ok, then put a temporary 12v line to that from the battery and see if you get power? if so, check the line going to it.
