Dead Cylinder
Old Jul 30, 2005 | 02:14 PM
v0va's Avatar
Russian Pimp
Dead Cylinder
Wtf has been going on, my car has been running like s***, I'm so damn sick of it, ran decently this morning if you dont mention the erratic idle at 1200, on the way home a knocking noise started but by the time I ended up in my garage it was all fine, then 2 hours later started up the car and knocking and weird *** noise starts coming out of the engine bay, Idles at 900 which is unusual bc my car idle so damn high, so I take out my BlaZt software and go one by one turning off each cylinder, then I come to #4 and when I turn it off, nothing happens and the car still runs the same, so I guess its number, but how could it get messed up like that out of no where, God its days like these I jsut want to sell my Z and get a reliable car. Which I think i might do.
Old Jul 30, 2005 | 04:56 PM
bardabe's Avatar
Bad Speller
your injector might have gone bad. your coil pack, coil pack conector, spark plug. check tehm all. I'd start withthe injector.
Old Jul 30, 2005 | 06:07 PM
nis88300zx's Avatar
congrats you did a cylinder cutout test on your engine.we do them alot on the engines down at the shop ;^) but as bardabe stated check your injector first that is really your best bet. down at the shop 95% of all trucks that have cylinder cutout tests done to them.and have a cylinder showing no response when cutout, end up having a bad injector. gl.
Old Jul 30, 2005 | 07:13 PM
Seraphic's Avatar
Loves The Asian Chicks
blehh... the injectors on these things are bitches >.< Ive thought about selling my Z before, hence all the headaches ive had with it, the sad thing is, is that when my hardware comes in i still wont be able to drive it because i cant afford the insurance T_T
Old Jul 30, 2005 | 09:59 PM
Riz Z Speed's Avatar
Administrative Brown Guy
aww crap, that sucks Vlad.
well, imma see if i can hook you up with those TT injectors soon
Old Jul 31, 2005 | 01:22 AM
v0va's Avatar
Russian Pimp
I'm taking the car to the mechanic on monday and have them fix the **** out of it and try selling it, Its too much for me to maintain this car, if I had another daily driver I would keep it but my car was already modded by the previous owner and this thing is not very reliable, I'm sick of worring if my car will start up. I think I might have found a replacement.Link
Old Jul 31, 2005 | 01:27 AM
entropy31's Avatar
The Cake Is A Lie!
you think a z is expensive to maintain, look up some of the parts for that bimmer. and if you have to take it to a shop, well......$$$. and the z is prettier anyways.
Old Jul 31, 2005 | 09:27 AM
v0va's Avatar
Russian Pimp
Yea I love my z, but how bad is it to drive on 5 cylinders since I have to drive it to the shop.
Old Jul 31, 2005 | 03:35 PM
NISMO LMR's Avatar
Go to Advanced, or Auto Zone... Buy a Compression Test Gauge, and test Cylinder Number 4. See what the Compression is compared to the other Cylinders. Like Bardabe said, test the Injectors, Coil Packs, etc.
It shouldn't be that hard to find out what the problem is.
Good luck with it Vladdy
Old Aug 1, 2005 | 05:25 AM
DanZ32's Avatar
Dan's the Man
Vlad. Injectors go on these cars all the time. You will be fine driving it to the shop just don't push it to hard. A drive often will even clear the injector problem. i.e. it will begin to fuction again (it will still likely be slightly out of spec and need replacing even if this does happen).
Unless you have replaced injectors recently, I suggest biting the bullet and replacing all 6. When 1 goes, another is not usually too far behind.
As Nismo & Bardabe suggested, test the injectors with an Ohm meter. Another less scientific method to test would be to leave the car idling and begin to remove your coil pack connectors one by one (just pull straight up, they should come off). If the idle noticeably dropped/fluctuates, that one is okay. Replace connector and move on to the next, etc until you pull a connector and you notice no change in idle (that one is the problem).
Hang in there and good luck
Old Aug 4, 2005 | 06:56 PM
v0va's Avatar
Russian Pimp
Aight so my car will be out of commision until Mon/Tues the guy said the reason my car ran funky and sometimes didnt want to start is some electrical problem where the cylinder didnt get enough voltage to run properly or something like that, he said they have the car apart right now and waiting for replacement parts and will prolly have it put back togather next week. sounds weird.
Old Aug 4, 2005 | 07:26 PM
yeah, it does sound weird.
keep us posted.
Old Aug 4, 2005 | 08:19 PM
DanZ32's Avatar
Dan's the Man
Vlad, I'm hoping they gave you more specifics than that and you are comfortable with it.
Having the car apart and waiting for replacement parts on an electrical issue sounds weird.
Good luck.
Old Aug 4, 2005 | 08:30 PM
v0va's Avatar
Russian Pimp
Well, I trust them, my mom has been in business with them for over 3 years, and the owner is pretty cool, he actually liked my car unlike everyother place i went to where htey were like, sell this pos and buy a camry it will be better for you. they also had a white z in the lot, i think it was for sale, but as soon as i get it fixed ill check it all out myself and i want a written write up of everythign they did, my damn idle better be fixed too, or ill be pissed, n cry.
Old Aug 4, 2005 | 09:03 PM
v0va's Avatar
Russian Pimp
and yea after missing my car for 2 days and looking at the pics, i dont think any other car loooks a even a bit as sexy as the z this one is a keeper.
Old Aug 4, 2005 | 09:27 PM
bardabe's Avatar
Bad Speller
pffffffft!!!! 2days?! WEACK SAUCE!!!!!!!! it's bin 6 months for me.
Old Aug 4, 2005 | 09:33 PM
91zxtt's Avatar
You can both have a nice big glass of shut the hell up. 9 months + for me. That little 12 mile jaunt doesn't count. The closest thing I can think of to compare to that emotional trauma would be paying a hooker $4k and thinking you'll get to do everything and anything you want, but all she ends up doing is kicking you in the *****.
F that.
Old Aug 4, 2005 | 09:40 PM
bardabe's Avatar
Bad Speller
F that.
I know when I'm beat.
Old Aug 10, 2005 | 12:21 PM
v0va's Avatar
Russian Pimp
Well my friend is picking up my car for me today because I have work, I still have no freaking idea what he did but he say's it runs perfect, it better run perfect for 1300$ price, I better get a page long invoice on the stuff that was changed.
Old Aug 10, 2005 | 03:18 PM
wow.
that's expensive.
wonder how much of that was labor?
Old Aug 10, 2005 | 03:52 PM
Fast240Z's Avatar
F that.
I feel your pain. My Z has been down for over a year.
Old Aug 11, 2005 | 04:57 PM
v0va's Avatar
Russian Pimp
Wooohooo, got my car back, greatest feeeling ever, its soo much more responsive, all they did is changed an injector and cleaned all the other ones, it still idle a little high 900-1100 but its not as bad as 1500-2000 that it usually did, but the best part is it cost us $0
Old Aug 11, 2005 | 05:10 PM
how did it cost you $0?
if they didn't charge you labor, they shoulda at least charged you for the injector.
how'd you pull that one off??
Old Aug 11, 2005 | 06:09 PM
v0va's Avatar
Russian Pimp
Lots of sexual favors..............
Naw, my mom knew the guy and he did her a favor and didn't charge us, his birthday is coming up soon and were gona get him something nice for being so nice, he said my car was awesome, he took it home a few times to make sure everything was working fine and he said he fell in love with it. Man I love my z, she drives like a beauty!!!
problem child
Dec 19, 2013 09:15 AM
blckdrgn
Apr 9, 2012 07:55 PM
hondatoz32
Oct 27, 2010 05:29 PM
Sweets
Feb 8, 2010 06:49 PM
azndan
Apr 17, 2008 07:45 AM
