Clutch Fluid Issue Again
Old Sep 25, 2008 | 08:28 AM
3riCJbOi's Avatar
one sound fits all
hey people i really need some help again
its rather strange there are no signs of any leakage but yet i have to refill my clutch fluid in my Z like every two weeks
is that even normal ?
One of my friends told me that it could my fluid thats its bad or old or something like that told me to go buy some fresh new ones
it'll be great to get some info so i know what to do or whats going on
thanks
Old Sep 25, 2008 | 12:53 PM
You should have posted this update in your old thread ( https://www.zdriver.com/forums/300zx-z32-forums-7/clutch-fluid-26280/ ) so we can all remember what has or hasn't been done yet.
Old Sep 25, 2008 | 04:38 PM
ZLover4Life's Avatar
Encyclopedic Knowledge
Bad fluid wouldn't really cause that problem. You have a leak. Get under the car, have a friend repeatedly pump the clutch... look around.
Old Sep 25, 2008 | 05:05 PM
KasbeKZ's Avatar
Pr0n Addict
i'm betting that it's inside. it can soak into the carpet
Old Sep 25, 2008 | 07:48 PM
Not very likely. If the gasket that seals the piston at the clutch master cylinder was leaking, it would likely leak more down the firewall. And if it's leaking down his firewall, brake fluid strips paint - he'd see that very clearly.
Old Sep 25, 2008 | 08:08 PM
KasbeKZ's Avatar
Pr0n Addict
i don't know. it's happened to me before. don't remember if it was in the z or the midget though
Old Sep 25, 2008 | 09:18 PM
3riCJbOi's Avatar
one sound fits all
i tried looking for signs of leak but i don't see any, the fluid is leaking quite slowly within two weeks or so i need to add some more, even with someone pumping the clutch i didn't see anything
could it be the slave cylinder leaking?
Old Sep 25, 2008 | 09:33 PM
my seal went out on my master leaked INTO the cabin... its the damnedest thing but it happens.
Old Sep 25, 2008 | 10:10 PM
KasbeKZ's Avatar
Pr0n Addict
it could be. it could be anywhere. you will just have to clean every potential spot REALLY well. maybe put some kind of powder on it so that it's more evident if it gets wet. if that makes sense. but you couldn't drive it in the rain then. i don't know
Old Sep 25, 2008 | 10:39 PM
Slave cylinders are problematic on Z32's. Did you get under the car and look like I said to do? Because if you're asking that question, I'll bet you didn't. Clearly the leak is slow, but it must exist.
Put a piece of cardboard under the slave cylinder area when it's parked. Check it the next day. If there's a stain on it, it's leaking.
Old Sep 26, 2008 | 07:56 PM
Goofyz's Avatar
The problem with brake fluid
is when its new, it dries quickly and doesn't leave much of a stain on concrete. You might need to leave some cardboard under the car overnight and check it in the morning to find where it’s leaking from, like that guy above me said. Do you still have the stock exhaust on this car? Is your commute long? Perhaps you are burning it off.
Old Sep 27, 2008 | 03:30 PM
3riCJbOi's Avatar
one sound fits all
yes i have the stock exhaust and i place a cardboard under the and there were some stains on it, not much but there was a bit
So i guess the slave cylinder is leaking
Old Sep 27, 2008 | 03:45 PM
Lucky it's that and not something else - slave cylinders are cheap. I recommend also getting a braided stainless steel line while you're at it - the line could be the source of the leak and the braided line will also increase pedal feedback.
Old Sep 28, 2008 | 12:17 AM
turboboost's Avatar
Yeah, just replace the slave and master.
PCressey
Apr 16, 2015 01:13 PM
iwithnell
Aug 16, 2014 04:40 PM
Sam
Mar 31, 2011 04:43 AM
3riCJbOi
Jul 24, 2008 10:41 AM
