Clutch Fluid Issue Again
hey people i really need some help again
its rather strange there are no signs of any leakage but yet i have to refill my clutch fluid in my Z like every two weeks
is that even normal ?
One of my friends told me that it could my fluid thats its bad or old or something like that told me to go buy some fresh new ones
it'll be great to get some info so i know what to do or whats going on
thanks
thanks
You should have posted this update in your old thread ( https://www.zdriver.com/forums/300zx-z32-forums-7/clutch-fluid-26280/ ) so we can all remember what has or hasn't been done yet.
Not very likely. If the gasket that seals the piston at the clutch master cylinder was leaking, it would likely leak more down the firewall. And if it's leaking down his firewall, brake fluid strips paint - he'd see that very clearly.
i tried looking for signs of leak but i don't see any, the fluid is leaking quite slowly within two weeks or so i need to add some more, even with someone pumping the clutch i didn't see anything
could it be the slave cylinder leaking?
it could be. it could be anywhere. you will just have to clean every potential spot REALLY well. maybe put some kind of powder on it so that it's more evident if it gets wet. if that makes sense. but you couldn't drive it in the rain then. i don't know
Slave cylinders are problematic on Z32's. Did you get under the car and look like I said to do? Because if you're asking that question, I'll bet you didn't. Clearly the leak is slow, but it must exist.
Put a piece of cardboard under the slave cylinder area when it's parked. Check it the next day. If there's a stain on it, it's leaking.
The problem with brake fluid
is when its new, it dries quickly and doesn't leave much of a stain on concrete. You might need to leave some cardboard under the car overnight and check it in the morning to find where it’s leaking from, like that guy above me said. Do you still have the stock exhaust on this car? Is your commute long? Perhaps you are burning it off.
Lucky it's that and not something else - slave cylinders are cheap. I recommend also getting a braided stainless steel line while you're at it - the line could be the source of the leak and the braided line will also increase pedal feedback.
