Apexi AVC-R wiring help
Old Nov 15, 2008 | 06:57 PM
92fairladyz's Avatar
I've got a dinosaur of an AVC-R. It is even older than the one titled "Gen 1" in the .pdf I have. I called Apexi USA and they said they don't have documentation dating back that far. They said to call Apexi Japan but nobody there spoke a lick of English. I have all the hoses run already. What I really need to know is what wires go where. I can't screw that up or I will really screw my car up as a result.
Here are pics of my old school model. There are 2 plugs that go into the back of the unit as well as a thing that says "BOOST IN" which I am guessing means I need to T off the boost gauge and go into the AVC-R unit. The 2 plugs on the back of the unit come together and then go to the solenoid. Three other wires branch off to go to the ECU. They are red, black, & green. Anybody know what wire is to what for this model?
Here are some pics:
BTW, that little connector packed with the unit in the 3rd pic is nowhere to be found. Must have gotten lost in the move. Not sure if it even went to the unit though as there is nowhere for it to plug in.
Old Nov 15, 2008 | 07:32 PM
Unless you've already discovered other wires for power & ground, I'd say that's what red & black are for. I did a quick intraweb search and found that the basic need to tap into the ecu is for duty cycle signal (apparently everyone hates that Apexi option) and engine RPM. Did you check out the write-up on tt.net? http://www.twinturbo.net/nissan/300z...avcr/avcr.html
Old Nov 15, 2008 | 08:54 PM
ZLover4Life's Avatar
Encyclopedic Knowledge
I don't hate that option... I like knowing how hard my injectors are working.
And I'd say the wiring is probably very similar to that of the writeup posted on tt.net, so follow that.
But ultimately... just looking at that thing... I'd never install that in my car. That thing is beat to sh*t.
Turbo86
Apr 18, 2006 08:07 AM
carloz
FS: 300ZX (90-96)
Feb 4, 2005 12:05 AM
carloz
FS: 300ZX (90-96)
Feb 2, 2005 01:03 PM
liebl
Nov 4, 2002 02:41 PM
WANTED300zx
Sep 9, 2002 12:30 PM
