Anyone know any tricks to remove stripped bolt
Old Mar 28, 2006 | 04:51 PM
forcedfedz32's Avatar
Im trying to remove the last 6mm hex bolt out from the top waterpipe. The inside is stripped and its a real tight spot. I tried hammering a 7mm but thats not working. Only other thing i could think of is getting one of those gator grip things. Any info would be must appreciated
Old Mar 28, 2006 | 05:10 PM
CanyonCarver's Avatar
Jack Of All Trades
Is it the hex that is stripped or the threads? If it's the hex, your best bet is to get the gator-grip, or whatever. Have you tried any inch-size sockets?
8mm hex is approx. .320". You might try a 5/16" socket which is .312"
Old Mar 28, 2006 | 05:42 PM
its a circilar bolt and the hex pattern in the middle is stripped. I did try but since its circular nothing is working. Im heading down to home cheapo later and buy the gator grip and see if that works.
Old Mar 28, 2006 | 06:15 PM
jfairladyz's Avatar
Vice grips are one option. If you can't get grip on the head then grind two opposite sides of the head flat so you can grip it with a wrench. Give it a couple whacks to try to break it loose before trying to get it out again.
Old Mar 28, 2006 | 06:19 PM
Jack Of All Trades
Doh, I was trying to remember where the 6mm came in at. It's a hex wrench. Sorry..... senility. Try tapping in a 1/4" hex wrench.
Also, if you have a heat gun, hair dryer, or halogen light, try getting one of them up close to the bolts for a while to heat it up. The bolts are Loctited in and some heat will help soften up the Loctite.
Old Mar 29, 2006 | 10:03 AM
bardabe's Avatar
Bad Speller
Don't forget to spray some PB blaster (penetrating lube) to loosen up the locktite. it;s non flamable so don' be scared to heat it up afterwards.
Old Mar 29, 2006 | 10:40 PM
I got the bolt out with a irwin stripped bolt kit. It was 20bucks at home cheapo comes with 5 different sizes bolts . I hammered it in and gave it a hard pull and she broke lose. Thanks for all the info guys i really appreciate it.
hoov100
Nov 18, 2008 12:37 PM
iestyn.lewis
Nov 13, 2008 07:17 AM
Shameless
Apr 24, 2006 06:12 PM
AllmyZs
Mar 13, 2004 04:32 PM
