1996-twin turbo white smoke
Old Oct 31, 2019 | 03:27 PM
speed622's Avatar
Hello fellow members..new to the z 32...i have a 1996 twin turbo..with only 80k miles....but a friend was following me,,in his car....noticed white smoke..can be bad turbo ..if i only have 80 k miles..car has lots of power..need input
Old Oct 2, 2021 | 12:56 AM
dsoixk's Avatar
Suddenly everyone in cold weather countries has possible head gasket failure on their minds.
Kodi nox
Old Nov 29, 2021 | 11:49 PM
Stilltooslow's Avatar
Cooling system pressure test
You should perform a cooling system pressure test. Observe if pressure drops. Look for any external coolant leaks. It may point to an internal one. If pressure is stable. Observe if coolant/smoke is more present when engine is cooler(not at full operating temperature. Would point to a head gasket leak when cold. If pressure drops, listen for leak. Might require a special stethoscope designed for listening for air leaks.
Prokopas
Mar 4, 2011 01:03 PM
c-murder
Oct 29, 2006 05:24 PM
xsciuga
Jan 3, 2006 03:37 PM
rngrck
Jul 22, 2003 09:55 AM
Togish1
Sep 17, 2002 08:34 AM
