1996-twin turbo white smoke
Hello fellow members..new to the z 32...i have a 1996 twin turbo..with only 80k miles....but a friend was following me,,in his car....noticed white smoke..can be bad turbo ..if i only have 80 k miles..car has lots of power..need input
Cooling system pressure test
You should perform a cooling system pressure test. Observe if pressure drops. Look for any external coolant leaks. It may point to an internal one. If pressure is stable. Observe if coolant/smoke is more present when engine is cooler(not at full operating temperature. Would point to a head gasket leak when cold. If pressure drops, listen for leak. Might require a special stethoscope designed for listening for air leaks.
Prokopas
Mar 4, 2011 01:03 PM
