Suspension upgrade
Old Sep 16, 2006 | 04:34 PM
oldschool's Avatar
Suspension upgrade
I have a 91 300ZX TT and I wanted to upgrade the F&R suspension. Will I be able to use a non-adjustable shocks on my car since it came with adjustable susupension. I have the KYB GR2 Gas shocks in mind. Will this work or do I have to get the adjustable version?
Old Sep 16, 2006 | 06:33 PM
Let me help ya out here... https://www.zdriver.com/forums/searc...searchid=80832
Old Sep 16, 2006 | 07:29 PM
ZLover4Life's Avatar
Encyclopedic Knowledge
You can use any shock, whether it's adjustable or not, but the GR2 shocks aren't considered to be very good. Most people (myself included) recommend KYB AGX (which are adjustable), Tokico Illumina (also adjustable), or Tokico Premium Performance (non-adjustable).
Old Sep 16, 2006 | 09:03 PM
oldschool's Avatar
Whats wrong with the GR2 shocks? I have the KYB AGX on my Trans Am. It works good but its a PITA sometimes to adjust it because I have to crawl or lay on the ground to adjust and to see the numbers on the dial. I think Tokico would be a better choice since it can be adjusted on top.
Old Sep 16, 2006 | 11:11 PM
Have fun removing ALL of the rear interior panels to adjust the rear shocks with Tokico Illumina (FWIW, I have Illumina up front, but I won't put them in back for that reason... when my stock rear shocks die, they'll be swapped for AGX). And if you said you don't want adjustment anyway, why not just get adjustable ones and leave them alone on whatever setting you're happy with?
As for GR2, most complain that they are simply too stiff (and there is such a thing as too stiff... a well tuned suspension will have some travel). The general consensus (at least on TT.NET from what I've seen) is that stock shocks are superior than GR2's, and that AGX (and Tokico Illumina to a lesser extent) are the generally accepted best replacement. Also, the GR2s aren't meant to ever be lowered, so if you intend on lowering the car, it'll only make the ride worse (if that matters to you... it does to me, because my car is lowered about 1.5").
Old Sep 17, 2006 | 12:30 AM
oldschool's Avatar
What about the Tokico HP premiun is it better than KYB GR2? Like you said I am lowering my car atleast 1"-1.5" will the Tokico HP premiun be compatible for a lowered car?
Old Sep 17, 2006 | 03:57 AM
entropy31's Avatar
The Cake Is A Lie!
i'll 2nd putting the AGX in back if you want adjustable. lying on the ground is much easier than pulling out the hatch interior, or i guess you could drill ugly holes. i dont have the AGXs personally, but i have driven a car with them, and eibach springs, and it felt pretty damn good compared to stock.
and thread belongs in the brakes/wheels/suspention/chassis section. moved.
Old Sep 17, 2006 | 10:26 AM
oldschool's Avatar
I want to lower my car atleast 1"-1.5" will it be OK to use a non-adjustable TOKICO HP Premium.
Old Sep 17, 2006 | 10:53 AM
could fit the electronic adjuster under there is you go with tien. but spend a small fortune.
Old Sep 17, 2006 | 04:08 PM
Guys, ****, he flat out said in the first post that he wasn't looking for an adjustable suspension... I threw out the Illumina and AGX as better alternatives to the GR2, which are unfavorable for the 300ZX.
oldschool - I said in my first response that the Tokico Premium shocks (aka HP Premium) are a good alternative.
Old Sep 17, 2006 | 04:30 PM
well, he asked if he can use a non-adjustable suspension. but i guesss you could assume straight from there thatts probably what he wants then huh. all this talk about adjustable suspension and crap i just jumped in in easier ways (more expensive) to adjust them. our bad
Old Sep 17, 2006 | 06:49 PM
oldschool's Avatar
Thanks for the advice guys.
ZLover4Life- I'm going for the Tokico premiums like you said. I just won the bid on ebay for a set(4) Tokico premiums for $232.00 I can't wait to get it together with my Eibach springs.
Old Sep 17, 2006 | 09:19 PM
Good choice - enjoy.
Old Sep 21, 2006 | 02:56 PM
Goofyz's Avatar
If you do it right
You can make removable covers so you can get to the adjustments on the top from the interior, I did it with a Dremel and for covers I used plastic faucet hole covers that can easily be popped on or off for adjustments. The trick is to measure where to cut the hole for them extreemely well before actually cutting the interior panel. You can get the covers in the plumbing isle of a Lowes or Home Depot for about 2$ each. The Dremel or Rotozip is slightly more. ( I went with Coil overs for a completely different feel)
KoolMan
Aug 23, 2012 12:15 PM
tonsoffun300zx
Aug 29, 2008 06:45 PM
Jays_Z
Feb 9, 2006 08:11 PM
johnZboy
Oct 9, 2004 11:14 AM
uc1tufz
Sep 25, 2002 05:37 AM
