Front end wobbles under medium braking
Old Jan 28, 2007 | 07:51 PM
  #51
SoCal-s130's Avatar
Returning Bleach Groupie
Can we change snw's title to "Site's Horn Dog" ???
Old Jan 28, 2007 | 09:33 PM
  #52
hmmm.. truthfulll but missing the catchy cleverness... lol
Old Jan 29, 2007 | 05:31 AM
  #53
CanyonCarver's Avatar
Jack Of All Trades
He needs his Ritalin meds adjusted for his Advanced Damned Horniness Disorder.
Old Feb 4, 2007 | 01:52 AM
  #54
ezramoore's Avatar
From: Port Townsend (Home) and Bellingham (School), WA
This may have been coverd, but: Are the rotor sizes the same accross all z32s? I know the 90 likes to be unique. Heres a link to the ones I was looking at.
Just saw them, asking what u all think
http://www.1motormart.com/unified/bu...2&make_code=NI
Old Feb 4, 2007 | 09:29 AM
  #55
90's are smaller....
after that they increases the rotor size some i believe cause the braking was underpowered on these cars.. and even with the upgrade they were still under powered. but if your adding after market ones shouldnt matter.. just gotta make sure youll have wheel clearence for the calipers
Old Feb 4, 2007 | 01:37 PM
  #56
Jack Of All Trades
You might re-read post #12. You might try finding the manufacturing date on your car. There's a sticker, maybe on the inside lid of the center console storage area or one on the radiator support. It will show the manufacture date of your car. It has to be 07/90 or later for those rotorz to work. Even then, someone could have already put the larger calipers and rotorz in your car. There's no way to be sure without measuring the rotorz that you have now.
Or, you can assume, and hopefully get lucky.
Old Feb 6, 2007 | 08:32 PM
  #57
Alexztt's Avatar
I'll get you the minimum machining specs for the rotors tomorrow in case they aren't on the rotor. Also I saw a TSB from Nissan about intake cam sprockets making a clicking noise I'll try to get you so more info.
Old Feb 7, 2007 | 05:45 PM
  #58
Alexztt's Avatar
The minimum machining specs for the front rotors on a 1990 are .945 inches and 1991 are 1.102 inches the rears for both years are .630 inches.
The TSB (technical service bulletien) number for the intake cam sprocket tapping is 92016 if you go to your local dealer they can print it for you. It will tell you what to look for, what cars it applies to, the parts you need to fix the problem and basically how to do it.
Old Feb 8, 2007 | 01:46 AM
  #59
ezramoore's Avatar
Thanks Alex!
Old Feb 8, 2007 | 10:11 AM
  #60
ezra... where you been? whats the update status on the ladies Z..... give us a story. lol
Old Feb 8, 2007 | 06:40 PM
  #61
ezramoore's Avatar
I've been in denial. lol.
The Z has an appointment with a local mecahnic with a penchant for Zs. Hes a great guy and so far (hes been doing work for my family for years) a great mechanic. Sadly, the appointment isn't until the 27th. I'm going to go out and rerun the speaker wire to eliminate that goddamned whine. I got sixteen guage Monster, like 50 ft for 18.00 Any tricks anyone wanna clue me in on? For instance, is there a trick to wiring into the door (ie through that little sleeve that holds al the wires that go into the door)?
TIA
Ezra
Sorry for the abscence, denial...
Old Feb 8, 2007 | 07:18 PM
  #62
not really... remove the door panel is all i can think of... lol.. its just running wires.... thtas how i had to do it removing panels where necessary. but any ways.. what did carfax show you or w/e your prob was with the title not being clean and what is your current problem? runs wierd right?
Old Feb 8, 2007 | 11:28 PM
  #63
ezramoore's Avatar
yeah runs weird. Waiting on a full work up from the DMV on the title work. Gonnah call the state patrol. Anyone pay for the month of carfax that wants to run a report for me? Just hoping that its not a huge issue with the motor.
Old Feb 9, 2007 | 09:46 AM
  #64
only possible hue issue is if compression is gone from one or more sylinders... otehr wise it most likely wont be huge...
Old Feb 10, 2007 | 06:26 PM
  #65
Alexztt's Avatar
No problem
Dave Hamby
Oct 27, 2006 06:35 PM
hoov100
Jan 2, 2006 03:00 PM
iminsideurZ
12
Jul 28, 2005 05:36 PM
smokin1320
Nov 30, 2003 04:50 PM
