Steering wheel/quick disconnect
Old Jan 26, 2006 | 06:18 PM
shifty60h's Avatar
Has anyone put in an aftermarket steering wheel and/or a quick disconnect for it? Do you think that it would stick out more that the stock one, and could you hook it up yourself?
Old Jan 26, 2006 | 08:25 PM
Aphrodite's Avatar
Im sure it could be done yourself, if you have some patience and are a bit mechanically savvy... however they do say "professional installation recommended" for a reason I suppose...
Old Jan 29, 2006 | 10:11 PM
napoleonzheking's Avatar
F5 Hero
I'm pretty sure it's so you don't blow the airbag in your face. And it seems like i remember reading something about if you put a non airbag wheel in your car, you have to rewire something to 'trick' the ECU into thinking that the airbag hasn't deployed, something about the check engine light being on, or the car not starting bc it thinks it's deployed or something, I don't know, I may of been dreaming when I read that.
Old Jan 30, 2006 | 07:21 PM
yes, airbags i definatly agree. and to answer the other question most real aftermarket steering wheels do stick out more, that way you cna skot wya back to get ur feet hte clearence adn you have the wheel closer in ur lap so you cna move ur hands fater its not like out of reach, better personal control. also y they disconnect so you can get in easier.
Old Feb 1, 2006 | 06:29 AM
WhtFairLadyZ's Avatar
A buddy of mine just installed a nice MOMO piece on his Z. With the spacer and all the brakettry it fits pretty close to stock. There might be some difference, but I cannot tell. I would like to do the quick disconnect steering wheel myself. But I wont consider it until I do my racing seats and 4 point harness. Then I ll consider removing the airbag.
Old Feb 1, 2006 | 08:50 AM
Aphrodite's Avatar
Eh, didnt even consider the airbag since I have none
Old Feb 1, 2006 | 01:42 PM
RPS13_GZ32's Avatar
One more reason I'm happy to own a 90 w/o airbags
Old Feb 1, 2006 | 02:52 PM
frosty's Avatar
Did it require any welding?
Old Feb 1, 2006 | 03:40 PM
No i dont think so. I ll find out though.
Old Feb 1, 2006 | 04:37 PM
how are you gonna mount that 4-point racing harness? cuase most people bolt it to the floor but thats apparently wrong. your supposed top have a roll cage that or at least a bar that spans the cars width at the same height as the seat the pass over. i guess when its lower and you stop hard or get in an accident when ur body slides forward instead of pulling against your chest to stop you they will then pull downward and actually cause spinal injuries. just somethign i felt i should and sorry for the off topic-ness.
Old Feb 1, 2006 | 05:00 PM
Aphrodite's Avatar
I would think the only danger of downward motion is if the holes they pass through are in soft material so the belts would be able to move vertically instead of only pulling strait back
Old Feb 2, 2006 | 05:47 AM
I was planning on mpunting the lap belts to the two rear seat bolts and then strapping the shoulder harness belts to the rear strut tower bar. I ve seen alot of cars do it that way and it does not position the straps in that no mounting zone that everyone is talking about. I think it is like only 5 degrees of slope from the seat to rear strut tower brace.
Old Feb 2, 2006 | 04:12 PM
frosty's Avatar
This is very true...it has been proven in crash tests. If I remember right improper belt mounting angle was actually a contributing factor in Dale Earnhardts death. Along with compressing the spine it can cause the belts to tear.
joi_b
Jan 30, 2013 11:46 AM
Heat Rave R
Jul 1, 2009 08:28 AM
kevtt
Jun 27, 2005 04:44 PM
nis88300zx
Jun 14, 2005 02:57 PM
DarrellBuddy321
Apr 10, 2005 12:57 AM
