Removing Front Bumper Cover
Old Apr 22, 2005 | 02:23 PM
frosty's Avatar
How hard is it to remove the front bumper cover? I need to replace my headlight assembly and it looks like the easiest way is to take the bumper off. I've never removed or installed body parts before, is it just a couple screws and bolts? Thanks.
Old Apr 22, 2005 | 03:27 PM
Z_WRECKER's Avatar
it's not hard at all....Do you still have the plastic cover on the bottom of your engine? anway after you take that off, you will also have to unbolt the brackets that connect your fender and front bumper. after you take the nose piece, there will be some bolts for the rest of the bumper,and if memory serves me (been a while) you should be good to go. Don't forget to unclip the harness for the turn signals and fog lights
Old Apr 22, 2005 | 08:28 PM
91zxtt's Avatar
You'll have to remove the center panel as well. There are a few bolts that need to removed beneath that cover.
Old Apr 22, 2005 | 10:23 PM
Z_WRECKER's Avatar
thanx 91...been a while since i removed a front bumper on a Z
Old Apr 23, 2005 | 03:14 AM
turtleboy's Avatar
turtled user
You don't need to remove the fascia to remove the headlights. It makes it a little easier, buy also adds ~1.5 hours to the project.
Read this:
http://www.300zxclub.com/showthread.php?t=47769
Old Apr 23, 2005 | 07:39 AM
frosty's Avatar
Cool, think I'll give it a shot with the bumper on. Thanks.
KyleTheKid
Apr 20, 2015 06:33 AM
daveg56313
Jul 8, 2013 12:37 PM
skittle
Feb 9, 2007 08:15 PM
z32gizzle
May 7, 2005 11:36 AM
nasty1095
Mar 12, 2005 04:56 PM
